Thank's for your answer and sorry for direct posting, should be to list...
The file is not there at all. My directory contains following after failed start:
drwxr-xr-x 2 tomcat tomcat 4096 Feb 15 17:04 auth
drwxr-xr-x 2 tomcat tomcat 4096 Feb 15 17:04 filter
-rw-r--r-- 1 tomcat tomcat 1027 Feb 15 17:04 geoserver.jceks
-rw-r--r-- 1 tomcat tomcat 419 Jan 22 10:42 layers.properties
drwxr-xr-x 3 tomcat tomcat 4096 Feb 15 17:04 masterpw
-rw-r--r-- 1 tomcat tomcat 192 Feb 15 17:04 masterpw.info
-rw-r--r-- 1 tomcat tomcat 73 Feb 15 17:04 masterpw.xml
drwxr-xr-x 4 tomcat tomcat 4096 Feb 15 17:04 pwpolicy
-rw-r--r-- 1 tomcat tomcat 671 Feb 15 17:04 rest.properties
drwxr-xr-x 2 tomcat tomcat 4096 Feb 15 17:04 role
-rw-r--r-- 1 tomcat tomcat 436 Jan 22 10:42 service.properties
-rw-r--r-- 1 tomcat tomcat 436 Feb 15 17:04 services.properties
drwxr-xr-x 3 tomcat tomcat 4096 Feb 15 17:04 usergroup
-rw-r--r-- 1 tomcat tomcat 291 Jan 22 10:42 users.properties
All files are owned by tomcat and tomcat has also modification right for files and directories.
-pk
Wippies-vallankumous on täällä! Varmista paikkasi vallankumouksen eturintamassa ja liity Wippiesiin heti!
http://www.wippies.com/
Just shooting in the dark:
2013-02-18 10:04:49,720 WARN [config.CustomEditorConfigurer] - Passing PropertyEditor instances into CustomEditorConfigurer is deprecated: use PropertyEditorRegistrars or PropertyEditor class names instead. Offending key [orggeotools.util.Version; offending editor instance: org.geoserver.platform.util.VersionPropertyEditor@...5436...
Is it possible that this is the problem? Tomcat5 is not the newest tomcat. I am using Tomcat6 and there is everything working fine. Unpacking the war-file shows me that there isnt a config.xml in the war but after starting the tomcat there is one (and many more files). Perhaps this config is produced dynamically and the old tomcat-version is not working fine with geoserver?
Try using tomcat6 if the problem is still there.
And: What Java are you using? Oracle JDK6?
Stefan
-----Original Message-----
Sent: Thursday, February 21, 2013 6:01 PM
Subject: [bulk]: Re: [Geoserver-users] Geoserver fails to start
directories.
-pk
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_d2d_feb
Geoserver-users mailing list
