Andrea,
Thank you for the info. Will try to look in.
Pagarbiai,
Paulius Litvinas
GIS konsultantas
From: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com4…] On Behalf Of Andrea Aime
Sent: Thursday, February 25, 2016 11:20 AM
To: Paulius Litvinas | InfoEra <paulius@anonymised.com4…>
Cc: GeoServer Mailing List List geoserver-users@anonymised.coms.sourceforge.net
Subject: Re: [Geoserver-users] geoserver + geofence and WMSGetFeatureInfo
On Thu, Feb 25, 2016 at 9:47 AM, Paulius Litvinas | InfoEra <paulius@anonymised.com> wrote:
Using 2 users in geofence: admin and user. admin has all rights and can access everything. user can access one layer with readonly all attributes and some layer attributes are denied (NONE).
Faced a strange behavior as WMSGetFeatureInfo request changes the attribute order in response for user. For admin it lists and works ok.
Also tried with user1, who has access right for one layer and all attributes are readonly. Attribute order in response also is changed.
May anyone knows if this is normal behavior, bug or additional configuration is needed?
Maybe anyone knows how it works and who is responsible for the sort order?
The code restricting the attributes is here:
https://github.com/geoserver/geoserver/blob/master/src/main/src/main/java/org/geoserver/security/decorators/SecuredFeatureSource.java#L142
My guess is that the security properties coming from GeoFence are out of order compared to
the native layer ones. It should not be a hard fix to make, is it something you want to try to fix directly?
Contribution guide is here:
https://github.com/geoserver/geoserver/blob/master/CONTRIBUTING.md
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
