Hello Geoserver User List,
I encountered an error message when trying to warp a raster layer "on the
fly" using SLD. It should call the function "GeorectifyCoverage" and apply a
rendering transformation to the image based on some Ground Control Points
(GCP):
<Transformation>
<ogc:Function name="gs:GeorectifyCoverage">
<ogc:Function name="parameter">
<ogc:Literal>data</ogc:Literal>
</ogc:Function>
<ogc:Literal>gcp</ogc:Literal>
<ogc:Literal>[[[0, 0], [308639.500,
5154180.500]], [[0, 450], [308639.500, 5150929.500]], [[600, 0],
[315730.500, 5154180.500]], [[600, 450], [315730.500,
5150929.500]]]</ogc:Literal>
</ogc:Function>
<ogc:Literal>targetCRS</ogc:Literal>
<ogc:Literal>EPSG:32632</ogc:Literal>
</ogc:Function>
</ogc:Function>
</Transformation>
Unfortunately it reports upon request from OpenLayers:
Could not convert the value EPSG:32632 into the expected type interface
org.opengis.referencing.crs.CoordinateReferenceSystem for parameter
targetCRS
Nobody was able to even give me a hint on how to tackle that, so I address
myself to you in this matter. More details on my question can be found on
GIS Stackexchange
<http://gis.stackexchange.com/questions/65162/geoserver-georectification-via-sld-fails>
Best,
xandriksson
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-Georectification-via-SLD-fails-tp5064734.html
Ciao,
I have asked Daniele (who worked on this implementation) to check the
process to see if it can be used as is as a Rendering Transformation
(which means inside an SLD for doing
the GeoRectification on the fly). We'll keep you posted.
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
(GCP):
<Transformation>
</ogc:Function>
</ogc:Function>
</ogc:Function>
</ogc:Function>
</Transformation>
targetCRS
GIS Stackexchange
Best,
xandriksson
This SF.net email is sponsored by Windows:
Build for Windows Store.
http://p.sf.net/sfu/windows-dev2dev
Geoserver-users mailing list
you are direcly specifying the crs as a literal, therefore I think it doesn’t properly convert the provided CRS code to a proper CoordinateReferenceSystem object.
(We will check whether a proper converter exists for that, in the next days.)
You should let it take from the request. Please, check the attached examples.
warp.wps.xml represents a WPS request to be posted.
warp.sld.xml represents the SLD doing the renderingTransformation using the georectifyProcess.
As you can see, it deals with some env function which pass down the values using the parameter substitution mechanism.
As an instance,/geoserver/wms?LAYERS=mylayer&…&srs=EPSG:32632&env=gcp:values
width, height, bbox, crs are directly taken from the WMS request’s parameters.
Hope this helps.
Daniele
warp.wps.xml (2.21 KB)
warp.sld.xml (2.03 KB)
Ing. Daniele Romagnoli
Senior Software Engineer
On Thu, Jul 11, 2013 at 10:46 AM, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
Ciao,
the GeoRectification on the fly). We’ll keep you posted.
Simone Giannecchini
@simogeo
Founder/Director
I encountered an error message when trying to warp a raster layer “on the
fly” using SLD. It should call the function “GeorectifyCoverage” and apply a
(GCP):
data
gcp
5150929.500]]]
targetCRS
EPSG:32632
targetCRS
GIS Stackexchange
Best,
xandriksson
See everything from the browser to the database with AppDynamics
Get end-to-end visibility with application monitoring from AppDynamics
Isolate bottlenecks and diagnose root cause in seconds.
Start your free trial of AppDynamics Pro today!
http://pubads.g.doubleclick.net/gampad/clk?id=48808831&iu=/4140/ostg.clktrk
Thanks a lot! When the CRS parameter is passed to the SLD via a WMS request
instead of defining it in the SLD as a literal, GeorectifyCoverage accepts
it without complaints.
See the official documentation here
<http://docs.geoserver.org/stable/en/user/styling/sld-extensions/substitution.html>
for more info on variable substitution in SLD.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-Georectification-via-SLD-fails-tp5064734p5066468.html
