[Geoserver-users] GEOSERVER geotools rendering
Hi all, I’m adding a new datastore type Directory of spatial files (shapefiles) , the layers are properly viewed in Geoserver OpenLayers windows, but if I see the log I have the following error: 27 Oct 15:28:58 ERROR [geotools.rendering] - Transformation doesn’t convergence. org.geotools.referencing.operation.projection.ProjectionException: Transformation doesn’t convergence. at org.geotools.referencing.operation.projection.MapProjection.inv_mlfn(MapProjection.java:1399) at org.geotools.referencing.operation.projection.TransverseMercator.inverseTransformNormalized(TransverseMercator.java:217) at org.geotools.referencing.operation.projection.MapProjection$Inverse.transform(MapProjection.java:1050) at org.geotools.referencing.operation.projection.MapProjection$Inverse.transform(MapProjection.java:1105) at org.geotools.referencing.operation.transform.ConcatenatedTransform.transform(ConcatenatedTransform.java:440) at org.geotools.referencing.operation.transform.ConcatenatedTransformDirect.transform(ConcatenatedTransformDirect.java:80) at org.geotools.geometry.jts.Decimator.decimateTransformGeneralize(Decimator.java:479) at org.geotools.geometry.jts.Decimator.decimateTransformGeneralize(Decimator.java:283) at org.geotools.geometry.jts.Decimator.decimateTransformGeneralize(Decimator.java:241) at org.geotools.renderer.lite.StreamingRenderer$RenderableFeature.getTransformedShape(StreamingRenderer.java:3123) at org.geotools.renderer.lite.StreamingRenderer$RenderableFeature.getShape(StreamingRenderer.java:3066) at org.geotools.renderer.lite.StreamingRenderer.processSymbolizers(StreamingRenderer.java:2549) at org.geotools.renderer.lite.StreamingRenderer.processFeature(StreamingRenderer.java:2449) at org.geotools.renderer.lite.StreamingRenderer.drawPlain(StreamingRenderer.java:2306) at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:1927) at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:831) at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:550) at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:273) at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:143) at org.geoserver.wms.GetMap.executeInternal(GetMap.java:623) at org.geoserver.wms.GetMap.run(GetMap.java:279) at org.geoserver.wms.GetMap.run(GetMap.java:125) at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:320) at sun.reflect.GeneratedMethodAccessor215.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:302) at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:190) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:157) at org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:34) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179) at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:62) at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:36) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179) at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:87) at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:55) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179) at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:33) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179) at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:208) at com.sun.proxy.$Proxy112.getMap(Unknown Source) at sun.reflect.GeneratedMethodAccessor214.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:857) at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:268) at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:147) at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50) at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959) at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893) at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:968) at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:859) at javax.servlet.http.HttpServlet.service(HttpServlet.java:635) at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:844) at javax.servlet.http.HttpServlet.service(HttpServlet.java:742) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:230) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:165) at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:192) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:165) at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:192) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:165) at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75) at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71) at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71) at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:192) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:165) at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:192) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:165) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:316) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69) at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126) at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73) at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69) at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73) at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330) at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330) at org.geoserver.security.filter.GeoServerPreAuthenticationFilter.doFilter(GeoServerPreAuthenticationFilter.java:75) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69) at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91) at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53) at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73) at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330) at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213) at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176) at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:152) at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346) at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:192) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:165) at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:192) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:165) at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:192) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:165) at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:192) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:165) at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:192) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:165) at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:121) at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:192) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:165) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:198) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96) at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:478) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:140) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:80) at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:624) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:341) at org.apache.coyote.ajp.AjpProcessor.service(AjpProcessor.java:486) at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66) at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:861) at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1455) at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) at java.lang.Thread.run(Thread.java:748) geoserver version: 2.11.0 geotools version: GeoTools Version 17.0 os: ubuntu x86_64 x86_64 x86_64 GNU/Linux someone can help me? Regards, Ema.
Please check your spatial reference system and bounds for the dataset.
Spatial reference systems have a range in which they are computationally stable, beyond that (for example near the poles) some spatial reference systems do not work resulting in issues like you see above.
If your data is “invalid” (ie outside the valid area) consider using “compute for srs extent” rather than “compute from data” button when configuring your layer.
On 27 October 2017 at 07:32, geography79 <emanuele.notarnicola@anonymised.com> wrote:
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
Geoserver-users@anonymised.com.382…sourceforge.net
Jody Garnett
Hi Jody,
thanks a lot, the problem seems to be solved by computing from srs extent,
Ema.
2017-10-31 23:28 GMT+01:00 Jody Garnett <jody.garnett@anonymised.com>:
Jody Garnett
On 27 October 2017 at 07:32, geography79 <emanuele.notarnicola@anonymised.comcom> wrote:
Geoserver-users@anonymised.comrge.net
Dott. Emanuele Notarnicola
Geospatial Information Systems Expert
https://twitter.com/#!/GeographyEma
http://it.linkedin.com/pub/emanuele-notarnicola/20/88a/82b
