[Geoserver-users] GeoServer GeoWebCache for Virtual Earth Silverlight Control Article
Hi All:
Wrote an article on overlaying GeoWebCache tiles via GeoServer using the new Virtual Earth Silverlight control. Hope it helps somebody.
Mark
http://thegeolab.com/geoserver-geowebcache-virtual-earth-silverlight.aspx
GeoLab
www.thegeolab.com
303-828-7371
Nice. You can also convert the x,y,z directly to a WMS bounding box so you
can make a Non-GWC WMS request. That way you can use dynamic non-cached
layers in Virtual Earth Silverlight. Check out the code in the
GeoWebCache--it does all that Math :slight_smile:
Mark Rodrigo wrote:
Hi All:
Mark
GeoLab
www.thegeolab.com
303-828-7371
Geoserver-users mailing list
View this message in context: http://www.nabble.com/GeoServer-GeoWebCache-for-Virtual-Earth-Silverlight-Control-Article-tp22729383p22794317.html
Actually, and at some point we'll have to make a parameter dictionary with all these darn features, you can just append &cached=false (and metatiled=false too, if you like).
Barely mentioned at the bottom of http://geowebcache.org/trac/wiki/google_maps , the GeoServer plugin should allow cachebypass by default.
-Arne
Mark Rodrigo wrote:
Hi All:
Mark
GeoLab
www.thegeolab.com
303-828-7371
Arne Kepp
OpenGeo - http://opengeo.org
Expert service straight from the developers
