[Geoserver-users] GeoServer - GET CAPABILITIES WMS 1.3.0 ERROR
Good Morning everybody,
I have a problem with geoserver wms 1.3.0 get capability request.
I think two of the layes have lost their styles and I tried to delete them
through the geoserver interface and also using REST using the following
commands but they don't work properly:
1) DELETING THE WHOLE WORKSPACE
curl -u admin:geoserver -XDELETE -H
http://localhost:8080/geoserver/rest/workspaces/CLIMATE
A: Workspace not empty
2)DELETING THE DATASTORE
curl -u admin:geoserver -v -XDELETE
http://localhost:8080/geoserver/rest/workspaces/CLIMATE/coveragestores/SD_TT_4326_025DD
RISPOSTA: Coveragestore not empty
3)DELETING THE LAYER
curl -u admin:geoserver -v -XDELETE 'Accept: text/xml'
http://localhost:8080/geoserver/rest/workspaces/CLIMATE/coveragestores/SD_TT_4326_025DD/coverage/SD_TG_PLC_025D.xml
RISPOSTA: coveragestore not empty
4)ASSIGNING A STYLE TO THE LAYER
curl -u admin:geoserver -XPUT -H 'Content-type: text/xml' -d
'<layer><defaultStyle><name>TEMPERATURE_C</name><workspace>CLIMATe</workspace></defaultStyle></layer>'
http://localhost:8080/geoserver/rest/layers/CLIMATE:SD_TG_PLC_025D
RISPOSTA:Error persisting LayerInfoImpl[SD_TG_PLC_025D,
resource:CoverageInfoImpl[SD_TG_PLC_025D]] to
/var/lib/opengeo/geoserver/workspaces/CLIMATe/SD_TG_PLC_02500D/SD_TG_PLC_025D/layer.xml
Any suggestions?
Thanks in advance
Luca
View this message in context: http://osgeo-org.1560.x6.nabble.com/GeoServer-GET-CAPABILITIES-WMS-1-3-0-ERROR-tp5138311.html
Hi Luca,
You can try manually deleting the files (or pointing them to a “valid style”). They’re in your Geoserver data directory. I guess:
This transmission is intended for the named addressee(s) only and may contain confidential, sensitive or personal information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
And then delete the /CLIMATe/ directory and restart GeoServer.
Might want to make a backup of it.
Hopefully that’ll resolve the issue,
Jonathan
commands but they don’t work properly:
  1. DELETING THE WHOLE WORKSPACE
curl -u admin:geoserver -v -XDELETE ‘Accept: text/xml’
curl -u admin:geoserver -XPUT -H ‘Content-type: text/xml’ -d
‘TEMPERATURE_CCLIMATe’
Any suggestions?
Thanks in advance
Luca
“Accelerate Dev Cycles with Automated Cross-Browser Testing - For FREE
Instantly run your Selenium tests across 300+ browser/OS combos. Get
unparalleled scalability from the best Selenium testing platform available.
Simple to use. Nothing to install. Get started now for free.”
http://p.sf.net/sfu/SauceLabs
Geoserver-users mailing list
Thanks Jonathan!
It works fine.
Best
Luca
View this message in context: http://osgeo-org.1560.x6.nabble.com/GeoServer-GET-CAPABILITIES-WMS-1-3-0-ERROR-tp5138311p5138859.html
