[Geoserver-users] Geoserver GWC WMTS
We should get a bit more information. How do you know that axis orientation is wrong? Have you problems with some client? Can you name it? What is the result and what do you expect it to be? Could you write all the steps which are needed for reproducing your problem? I suggest to use some shapefile from OpenStreetMap extract http://download.geofabrik.de/europe/luxembourg-latest.shp.zip as a test data.
-Jukka Rahkonen-
Tarek Benamara wrote:
I try to add a WMTS Layer from my GeoServer but the issue still that the axis orientation wrong. I m using the EPSG 2169 for Luxemburg and generate the tiles with this Gridset
Inline-Bild 1
Have you any idea what is the issue?
WMTS URL =http://localhost/geoserver/gwc/service/wmts
Thank you!
Tarek Benamara
Tarek Benamara
Tarek Benamara
1.in Tile Caching of GeoServer I create firstly a new gridset for EPSG 2169 for Luxemburg with the Zoome Lavels 1-10 the Gridset bounds are Compute from maximum extent of CRS.
2.I configure the Caching Defaults with the Gridset of ESPG 2169
After that I add the WMTS of GWC to qgis
URL= http://localhost:8080/geoserver/gwc/service/wmts the data still not there
And I check IgnoreAxisOrientation in QGIS then I can see the layers in the right CRS
Thank you!
2016-01-13 11:38 GMT+01:00 Rahkonen Jukka (MML) <jukka.rahkonen@anonymised.com>:
-Jukka Rahkonen-
Inline-Bild 1
Thank you!
Tarek Benamara
Tarek Benamara
Tarek Benamara
Tarek Benamara
