Hello
I'm using geoserver 2.5 and i'm loading lots of data with .sld files. And i
get java.lang.OutOfMemoryError: Java heap space error. The computer i'm
using has 8gb memory and i want to improve the memory usage of geoserver.
As i understand after some research, i can do this on the wrapper.conf file.
Even i try to update some informations, i could't do it right i think.So how
should i change the wrapper.conf file to obtain higher memory?
By the way, i'm using it on windows as a service.
Any help would be much appreciated.
Mehmet.
Here is my wrapper.conf file :
# Wrapper Properties
# Java Application
wrapper.java.command=%JAVA_HOME%/bin/java
# Java Main class. This class must implement the WrapperListener interface
# or guarantee that the WrapperManager class is initialized. Helper
# classes are provided to do this for you. See the Integration section
# of the documentation for details.
wrapper.java.mainclass=org.tanukisoftware.wrapper.WrapperSimpleApp
# Java Classpath (include wrapper.jar) Add class path elements as
# needed starting from 1
wrapper.java.classpath.1=wrapper/lib/wrapper.jar
wrapper.java.classpath.2=start.jar
wrapper.java.classpath.3=lib/*.jar
# Java Library Path (location of Wrapper.DLL or libwrapper.so)
wrapper.java.library.path.1=wrapper/lib
# Java Additional Parameters
wrapper.java.additional.1=-Djetty.home=.
wrapper.java.additional.2=-DGEOSERVER_DATA_DIR="%GEOSERVER_DATA_DIR%"
wrapper.java.additional.3=-XX:MaxPermSize=128m
# Initial Java Heap Size (in MB)
wrapper.java.initmemory=16
# Maximum Java Heap Size (in MB)
wrapper.java.maxmemory=128
# Application parameters. Add parameters as needed starting from 1
wrapper.app.parameter.1=org.mortbay.start.Main
wrapper.app.parameter.2=etc/jetty.xml
# Wrapper Logging Properties
# Format of output for the console. (See docs for formats)
wrapper.console.format=M
# Log Level for console output. (See docs for log levels)
wrapper.console.loglevel=INFO
# Log file to use for wrapper output logging.
wrapper.logfile=logs/wrapper.log
# Format of output for the log file. (See docs for formats)
wrapper.logfile.format=LPTM
# Log Level for log file output. (See docs for log levels)
wrapper.logfile.loglevel=INFO
# Maximum size that the log file will be allowed to grow to before
# the log is rolled. Size is specified in bytes. The default value
# of 0, disables log rolling. May abbreviate with the 'k' (kb) or
# 'm' (mb) suffix. For example: 10m = 10 megabytes.
wrapper.logfile.maxsize=0
# Maximum number of rolled log files which will be allowed before old
# files are deleted. The default value of 0 implies no limit.
wrapper.logfile.maxfiles=0
# Log Level for sys/event log output. (See docs for log levels)
wrapper.syslog.loglevel=NONE
# Wrapper NT Service Properties
# WARNING - Do not modify any of these properties when an application
# using this configuration file has been installed as a service.
# Please uninstall the service before modifying this section. The
# service can then be reinstalled.
# Name of the service
wrapper.ntservice.name=GeoServer 2.5
# Display name of the service
wrapper.ntservice.displayname=GeoServer 2.5
# Description of the service
wrapper.ntservice.description=GeoServer is an open source software server
written in Java that allows users to share and edit geospatial data.
# Service dependencies. Add dependencies as needed starting from 1
wrapper.ntservice.dependency.1=
# Mode in which the service is installed. AUTO_START (for Automatic) or
DEMAND_START (for Manual)
wrapper.ntservice.starttype=AUTO_START
# Allow the service to interact with the desktop.
wrapper.ntservice.interactive=false
# Run service as Network Service
# wrapper.ntservice.account=NT AUTHORITY\NetworkService*
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-heap-size-permgen-space-configuration-tp5145590.html
