Thanks Andrea,
I thought there might be a good reason for limit. I ran the implications of this patch past my employer and in this case, they've decide to sidestep the problem by just displaying
"more then $SERVER_LIMIT records" instead of an exact record count.
I can see a use for having an exact record count though - I might have a crack at doing this outside of working hours. I'll be in touch on the developers list.
Geoff
From: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] On Behalf Of Andrea Aime
Sent: Tuesday, 22 January 2013 19:22
To: Geoff Williams
Subject: Re: [Geoserver-users] geoserver hit counts > server max features [SEC=UNCLASSIFIED]
I see. The limit is working on count too for good reasons:
- counting can be expensive (can take minutes) if you have datasets with tens or hundreds of millions of records
- the filter expressed in the WFS request can make it much worse, for example, you might filter on an
attribute that's not indexed, or use WFS 2.0 to ask for an expensive join
Is this something that's easy to change? Would there be any interest in a patch to allow this?
I believe it could be of interest, but it would have to be configurable, either a separate max value
for the count operation or a flag disabling the existing max for the count operation.
The classes to be modified would be WFSInfo, WFSInfoImpl (the configuration bits), the WFSAdminPage,
and the GetFeature class to take into account the above configurations.
Since this is an API change, it has to take place on the unstable series before (which, starting
from today, means the 2.4.x series, the 2.3.x series is entering hardening today in preparation
for the 2.3.0 release in a couple of months).
If you want to persue this please discuss the changes you want to make on the geoserver-devel
list.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
