[Geoserver-users] Geoserver horizontal clustering
Up !
Sorry to re-send the message but as I received no answer from my previous questions, I wish to try again …
Thx
I am running into problems configuring the jms clustering of Geoserver.
Here is the background:
I have 4 virtualboxes, each running a Geoserver 2.7.1 with the jms-cluster extension. I would like to keep the embedded broker in a matter of simpler installation. Also I would like to preserve this kind of peer to peer network because it supports easily the add or removal of node and because clients, do not have to know the broker network config.
However, my network admin announced me multicast will not be allowed in production environment. So as I know a priori the ip addresses of all the geoserver instances, I would like to change the multicast to a set of static ip setting the java property ‘activemq.transportConnectors.server.discoveryURI’ to ‘static:(host1,host2,etc.)’.
But I got a NullPointerException from activemq. I even tried to upgrade to latest version of activemq jars (as suggested by the fix - issues.apache.org/jira/browse/AMQ-5442) but it does the same: geoserver do not bootstrap. Here the top of the stacktrace:
21 Jul 10:26:04 ERROR [cluster.impl] - java.lang.NullPointerException at org.apache.activemq.transport.discovery.simple.SimpleDiscoveryAgent.start(Simple‌ ​DiscoveryAgent.java:92) at org.apache.activemq.broker.TransportConnector.start(TransportConnector.java:253) at org.apache.activemq.broker.BrokerService.startTransportConnector(BrokerService.j‌ ​ava:2593) at org.apache.activemq.broker.BrokerService.startAllConnectors(BrokerService.java:2‌ ​506) at org.apache.activemq.broker.BrokerService.doStartBroker(BrokerService.java:710)
Then I have disabled the embedded broker and install an external one (latest version) for each Geoserver VMs. Brokers can see each other and exchange messages. If I create a style from one Geoserver, the jms messages are sent to the other broker in the good topic. But the other geoserver does not retrieve the messages from its local broker… so the style is not imported…
Here is my configuration:
The activemq version was 5.11.1 and I got the same results the 5.9.0.
Can I have some hints to configure my geoservers with the embedded broker without multicast? Or, at least, hints for an external broker without mutilcast?
Rot.
Dear Roth,
please, find my answers inline below....
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Tue, Aug 25, 2015 at 9:01 AM, Rot Ulet <rotulet@anonymised.com> wrote:
Up !
questions, I wish to try again ...
Thx
I was about to say that this should be supported out-of-the-box with
the multicast approach but it looks like you can't use it.
There you go :slight_smile:
'activemq.transportConnectors.server.discoveryURI' to
'static:(host1,host2,etc.)'.
at
ava:2593) at
506) at
retrieve the messages from its local broker... so the style is not
imported...
* /etc/default/activemq pastebin.com/XARMtzQF
* activemq.xml pastebin.com/PTkpUhjP
* cluster.properties pastebin.com/CDKPKG2J.
mutilcast?
I believe I tried to help a bit with this kind of questions on Stackexchange.
The first config is something we never tried, It would need some of
our devs time to make sure it is supported and work properly.
About the second, this should work as well as it is one of the two
configurations that we usually uses (1 being the p2p embedded broker
with multicast).
You can find some additional information in this documents:
http://geoserver.geo-solutions.it/edu/en/clustering/geoserver/active/index.html#advanced-stand-alone-mom-configuration-and-usage
I would suggest to make sure that the various instances are acting as
slaves and that the connection with the broker is enabled (see the
cluster configuration page that is available once you deploy the jms
clustering extension in geoServer).
Let me know how it goes, it might also be wort to sayin with OS you
are using for the deploy.
Rot.
Geoserver-users mailing list
