Thank you very much for the answers.
The biggest issue is that there is no label collision detection and there’s no way to integrate an HTML image map on OpenLayers.
It’s likely that we will adopt other solution but, if not, we will contact you.
Best regards,
Bruno da Fonseca
From: maurobartolomeoli@…84… [mailto:maurobartolomeoli@…84…] On Behalf Of Mauro Bartolomeoli
Sent: terça-feira, 6 de Maio de 2014 09:38
To: Diego Guidi
Cc: Mauro Bartolomeoli; Bruno M. Fonseca; geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] Geoserver ImageMap extension
Hi Diego,
yes your changes are integrated but currently they are rendering each kind of mark as a circle. They are indeed a good starting point to implement rendering of other kinds of marks (square should be very simple, but we some effort all standard marks could be implemented).
The original version didn’t because when using an imagemap the original shape is not visible and from the user point of view there is not a big difference (in my opinion) in using different shapes, but probably there are use cases in which the shape is important.
Mauro
2014-05-06 10:28 GMT+02:00 Diego Guidi <diegoguidi@…84…>:
On Tue, May 6, 2014 at 9:36 AM, Mauro Bartolomeoli
<mauro.bartolomeoli@…1107…> wrote:
I think you need to change the getShape method to return a different shape
based on the current mark and also the writeGeometry method.
I’ ve made some changes that maybe can help you (I’m not sure are
integrated to geoserver official repository): http://goo.gl/eP789L
Diego Guidi
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via Poggio alle Viti 1187
