On Tue, Mar 15, 2016 at 12:34 PM, hanshupe <paul.schneeweiss@anonymised.com>
wrote:
I have already tried it with JAIEXT (In the JAI settings I just added all
JAIEXT operations to JAI operations - hope that was correct) and it didn't
change the output. I am currently using GS 2.8.0 btw., are there some
changes in GS 2.9.0 beta?
Hum... the fixes we have made so far have landed on 2.8.x too, you can try
2.8.2
But I don't remember a specific one indeed.
What confuses me is that my output is as expected when I add the layer
based
on a GeoTIFF file. Only the layer (with the same GeoTIFF imported in
oracle)
based on the ImageMosaicJDBC source shows the undesired background values.
Hence I assumed the problem comes from the ImageMosaicJDBC plugin and not
from GS?
Oh ok... then it might be that the image mosaic JDBC does not set the NODATA
properties? Unsure, I have no direct experience with that plugin
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
