[Geoserver-users] GeoServer Imagery Import
Hi everyone,
I am trying to import imagery into GeoServer. I am trying to serve aerial imagery to Google Earth.
So far, I have created the namespace (‘dc’), as well as tried to create a coverage store.
The following is all in regards to the Coverage Store:
My data is 31 ECW/EWW files. I have generated other formats from them using gdal_translate. I created tifs as well as png/png.aux.xml files.
Each file can be upto 64000 in either dimension. Most files are 64000x64000.
I named the Coverage Store dcimag just to match the folder name.
I placed all versions of the same tile into %geoserver_home%/data_dir/coverages/dcimag
In trying to import the pngs/ecws as raster files it says the following:
· "Invalid url: ‘file:coverages/dcimag/WDC_06c04.ecw’ for format type:‘WorldImage’.
· "Invalid url: ‘file:coverages/dcimag/WDC_06c04.eww’ for format type:‘WorldImage’.
· "Invalid url: ‘file:coverages/dcimag/WDC_06c04.png’ for format type:‘WorldImage’.
· "Invalid url: ‘file:coverages/dcimag/WDC_06c04.png.aux.xml’ for format type:‘WorldImage’.
In trying to import the tifs as tifs or tiffs it says the following:
· "Invalid url: ‘file:coverages/dcimag/WDC_06c04.tiff’ for format type:‘GeoTIFF’.
· "Invalid url: ‘file:coverages/dcimag/WDC_06c04.tif’ for format type:‘GeoTIFF’.
To confirm it has found the file, I tried a non-existant file and receive the following error:
· Could not find file: C:\Program Files\GeoServer 1.7.4\data_dir\coverages\dcimag\WDC_06c04.tif. Perhaps location was entered wrong?
Is there another way to organize/retranslate the data that would work?
I hope that this is enough information and that you have time available to help me with my problem.
Sincerely,
Hiren Hiranandani
hhiranandani@anonymised.com
Hi Hiren,
Are you sure you are specifying the right coverage format when creating the store. For serving ECW see docs here:
http://geoserver.org/display/GEOSDOC/ImageIO-ext+GDAL+extensions
And you will have to choose the correct format, not WorldImage.
Also, one thing to check is to ensure your paths are correct. Specifying the url:
Will resolve to <GEOSERVER_DATA_DIR>/coverages/dcimag/... Are you sure the files are in the correct location?
Hiren Hiranandani wrote:
Hi everyone,
· "Invalid url: 'file:coverages/dcimag/WDC_06c04.ecw' for format type:'WorldImage'.
· "Invalid url: 'file:coverages/dcimag/WDC_06c04.eww' for format type:'WorldImage'.
· "Invalid url: 'file:coverages/dcimag/WDC_06c04.png' for format type:'WorldImage'.
· "Invalid url: 'file:coverages/dcimag/WDC_06c04.png.aux.xml' for format type:'WorldImage'.
· "Invalid url: 'file:coverages/dcimag/WDC_06c04.tiff' for format type:'GeoTIFF'. <with filename changed to tiff>
· "Invalid url: 'file:coverages/dcimag/WDC_06c04.tif' for format type:'GeoTIFF'. <with filename left as tif>
Sincerely,
Hiren Hiranandani
hhiranandani@anonymised.com <mailto:hhiranandani@anonymised.com>
Crystal Reports - New Free Runtime and 30 Day Trial
Check out the new simplified licensing option that enables unlimited royalty-free distribution of the report engine for externally facing server and web deployment. http://p.sf.net/sfu/businessobjects
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
