Please tell me is it possible to disable in memory config storage and switch to store config directly to the file system? As I understand jdbcconfig plugin is not ready yet. Are there other ways to cluster geoserver with active config changes?
That says:
GeoServer in a clustered configuration.....
Regardless of the mechanism for synchronization, changes to the data
directory and the in-memory catalog will normally be directed by one master
GeoServer. This can be enforced by disabling the GeoServer user interface on
all “slave” GeoServers or by configuring the front-end load balancer to only
direct user interface requests to /geoserver/web to the master GeoServer.
*Changes to the master GeoServer’s data catalog must be explicitly refreshed
on slave instances.* This can be accomplished manually through the GeoServer
Admin web UI (/geoserver/web), or with some measure of automation (on a
schedule, or after a trigger is fired) using GeoServer’s REST API (e.g. by
sending a POST/PUT request to /geoserver/rest/reload?recurse=true).
You are not the only one waiting for that.
And I hope somebody proves me wrong.
Christian
____________________________
Dr Christian Maul
Project Manager
Information Services Branch
Department of Sustainability and Environment
Level13, Marland House, 570 Bourke Street
Melbourne 3000
