[Geoserver-users] Geoserver is not starting while running startup batch script
Hello,
I am trying to run an older version of Geoserver (Ver 2.15.1) on my Windows 10 (64 bit) PC. The script startup.bat starts and crashes. I have tried running the script with Admin privileges, changing port in start.ini (e.g. jetty.port = 8989) and reload, opening port in Windows firewall, nothing seems to work.
I also checked Windows services, but couldn’t find Geoserver as a service there.
Java_Home: set to JDK 11
GEOSERVER data dir points to data directory of Geoserver
Can someone give me some hints to fix this?
Here is the crash log via Windows CMD console:
:INFO:oejsh.ContextHandler:main: Started o.e.j.w.WebAppContext@anonymised.com{GeoServer,/geoserver,file:///C:/path_to/GeoServer%202.15.1/webapps/geoserver/,AVAILABLE}{C:\path_to\GeoServer 2.15.1\webapps\geoserver}
:WARN:oejx.XmlConfiguration:main:
java.security.PrivilegedActionException: java.net.BindException: Address already in use: bind
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.jetty.xml.XmlConfiguration.main(XmlConfiguration.java:1511)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.jetty.start.Main.invokeMain(Main.java:220)
at org.eclipse.jetty.start.Main.start(Main.java:486)
at org.eclipse.jetty.start.Main.main(Main.java:77)
Caused by:
at sun.nio.ch.Net.bind0(Native Method)
at sun.nio.ch.Net.bind(Unknown Source)
at sun.nio.ch.ServerSocketChannelImpl.bind(Unknown Source)
at sun.nio.ch.ServerSocketAdaptor.bind(Unknown Source)
at org.eclipse.jetty.server.ServerConnector.openAcceptChannel(ServerConnector.java:339)
at org.eclipse.jetty.server.ServerConnector.open(ServerConnector.java:307)
at org.eclipse.jetty.server.AbstractNetworkConnector.doStart(AbstractNetworkConnector.java:80)
at org.eclipse.jetty.server.ServerConnector.doStart(ServerConnector.java:235)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68)
at org.eclipse.jetty.server.Server.doStart(Server.java:395)
at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1572)
at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1512)
java.lang.reflect.InvocationTargetException
Caused by: java.security.PrivilegedActionException: java.net.BindException: Address already in use: bind
… 7 more
Caused by: java.net.BindException: Address already in use: bind
… 9 more
… 7 more
… 9 more
Usage: java -jar $JETTY_HOME/start.jar [options] [properties] [configs]
java -jar $JETTY_HOME/start.jar --help # for more information
I might be wrong but I think Java 11 needs a liter. version of GeoServer.
Why do you need the old version?
On 10 Jan 2022, at 19:10, Jibran Khan jk.envs@anonymised.com wrote:
Hello,
Caused by:
… 7 more
… 9 more
… 7 more
… 9 more
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Geoserver-users@anonymised.comourceforge.net
It looks like something else is already using that port, or you don’t have permission to use it.
Ian
On Mon, 10 Jan 2022, 19:07 Jibran Khan, <jk.envs@anonymised.com> wrote:
Hello,
Caused by:
… 7 more
… 9 more
… 7 more
… 9 more
