[Geoserver-users] Geoserver is timing out and crashing intermittently when a layer with large data is rendered
Hi Everyone,
We are having a GeoServer setup with a PostGIS database running on Jetty. The issue I am facing is that it times out often when trying to access a layer which is built with large data.
I have tried:
  • Enabled GeowebCache, direct integration with WMS service , but it does not help and it still crashes, so even if I do seeding, the data gets wiped off after it restarts. Not sure why a restart is removing the cache.
  • Tried to update a few rendering params such as max rendering memory : Five times of default(65536)
  • Updated JVM heap config to Xmx128m.
I would highly appreciate any help or suggestions!
Attaching the error logs :
 BgColor = java.awt.Color[r=255,g=255,b=255]
Buffer = 0
Clip = null
CQLFilter = [[[ hoco_num = 130317 ]]]
Crs = PROJCS["WGS 84 / Pseudo-Mercator",
GEOGCS["WGS 84",
DATUM["World Geodetic System 1984",
SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
UNIT["degree", 0.017453292519943295],
AXIS["Geodetic latitude", NORTH],
AXIS["Geodetic longitude", EAST],
AUTHORITY["EPSG","4326"]],
PROJECTION["Popular Visualisation Pseudo Mercator", AUTHORITY["EPSG","1024"]],
PARAMETER["semi_minor", 6378137.0],
PARAMETER["latitude_of_origin", 0.0],
PARAMETER["central_meridian", 0.0],
PARAMETER["scale_factor", 1.0],
PARAMETER["false_easting", 0.0],
PARAMETER["false_northing", 0.0],
UNIT["m", 1.0],
AXIS["Easting", EAST],
AXIS["Northing", NORTH],
AUTHORITY["EPSG","3857"]]
Elevation = []
Env = {}
Exceptions = SE_XML
FeatureId = null
FeatureVersion = null
Filter = [[[ test_val = 130310 ]]]
Format = image/png
FormatOptions = {}
Get = true
Height = 598
Interpolations = []
Layers = [org.geoserver.wms.MapLayerInfo@anonymised.com]
MaxFeatures = null
Palette = null
RawKvp = {REQUEST=GetMap, CRS=EPSG:3857, FORMAT=image/png, BBOX=-9547272.565037575,3909103.9755447335,-9221956.57265602,4091941.3472027867, VERSION=1.3.0, STYLES=green, SERVICE=WMS, WIDTH=1064, HEIGHT=598, CQL_FILTER=test_val IN (fdsf), TRANSPARENT=true, LAYERS=test_layer}
RemoteOwsType = null
RemoteOwsURL = null
Request = GetMap
RequestCharset = UTF-8
ScaleMethod = null
Sld = null
SldBody = null
SldVersion = null
SortBy = null
SortByArrays = null
SRS = urn:ogc:def:crs:EPSG:3857
StartIndex = null
StyleBody = null
StyleFormat = sld
Styles = [StyleImpl[ name=green]]
StyleUrl = null
StyleVersion = null
Tiled = false
TilesOrigin = null
Time = []
Transparent = true
ValidateSchema = false
Version = 1.3.0
ViewParams = null
Width = 1064
16 Jun 08:52:17 DEBUG [wms.map] - Writing png image ...
16 Jun 08:52:17 DEBUG [geoserver.filters] - Not compressing output for mimetype: image/png
16 Jun 08:52:17 DEBUG [wms.map] - Writing png image ... done!
16 Jun 08:52:17 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
16 Jun 08:56:12 DEBUG [geoserver.security] - AuthenticationCache Eviction task running
16 Jun 08:56:12 DEBUG [geoserver.security] - Cache entries #: 0
16 Jun 08:56:12 DEBUG [geoserver.security] - AuthenticationCache Eviction task completed
16 Jun 08:56:13 DEBUG [security.IncludeQueryStringAntPathRequestMatcher] - Checking match of request : 'Path: /web, QueryString: null'; against '/web/**'
16 Jun 08:56:13 DEBUG [security.IncludeQueryStringAntPathRequestMatcher] - Matched Path: /web, QueryString: null with /web/**
16 Jun 08:56:13 DEBUG [geoserver.filters] - Creating a new http session inside the web UI (normal behavior)
java.lang.Exception: Full stack trace for the session creation path
at org.geoserver.filters.SessionDebugFilter$SessionDebugWrapper.getSession(SessionDebugFilter.java:92)
at org.geoserver.filters.SessionDebugFilter$SessionDebugWrapper.getSession(SessionDebugFilter.java:66)
at javax.servlet.http.HttpServletRequestWrapper.getSession(HttpServletRequestWrapper.java:279)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:47)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:74)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:215)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:178)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:142)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:358)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:271)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1610)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:101)
at org.geoserver.filters.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:77)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:42)
at org.eclipse.jetty.servlets.CrossOriginFilter.handle(CrossOriginFilter.java:311)
at org.eclipse.jetty.servlets.CrossOriginFilter.doFilter(CrossOriginFilter.java:265)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:201)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:119)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1602)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:540)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1700)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1345)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:480)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1667)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1247)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144)
at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:220)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:152)
at org.eclipse.jetty.server.Server.handle(Server.java:505)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:370)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:267)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:305)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:698)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:804)
at java.lang.Thread.run(Thread.java:748)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366)
16 Jun 08:56:13 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2021-06-16 09:01:01.133:INFO:oejs.AbstractConnector:Thread-0: Stopped ServerConnector@anonymised.com{HTTP/1.1,[http/1.1]}{[0.0.0.0:8080](http://0.0.0.0:8080)}
2021-06-16 09:01:01.137:INFO:oejs.session:Thread-0: node0 Stopped scavenging
2021-06-16 09:01:01.138:INFO:oejshC.geoserver:Thread-0: Destroying Spring FrameworkServlet 'dispatcher'
2021-06-16 09:01:01.144:INFO:oejshC.geoserver:Thread-0: Closing Spring root WebApplicationContext
16 Jun 09:01:01 INFO [georss.GeoRSSPoller] - destroy() invoked
16 Jun 09:01:01 INFO [geowebcache.GeoWebCacheDispatcher] - GeoWebCacheDispatcher.destroy() was invoked, shutting down.
16 Jun 09:01:01 INFO [diskquota.DiskQuotaMonitor] - Disk quota monitor shutting down...
16 Jun 09:01:01 INFO [diskquota.DiskQuotaMonitor] - Shutting down quota usage monitor...
16 Jun 09:01:01 INFO [diskquota.QuotaUpdatesMonitor] - Shutting down quota usage monitor...
16 Jun 09:01:01 INFO [diskquota.QueuedQuotaUpdatesConsumer] - Shutting down quota update background task due to InterruptedException
16 Jun 09:01:01 INFO [diskquota.DiskQuotaMonitor] - Shutting down quota statistics gathering monitor...
16 Jun 09:01:01 INFO [diskquota.QueuedUsageStatsConsumer] - Shutting down quota update background task due to interrupted exception
16 Jun 09:01:01 INFO [jdbc.JDBCQuotaStore] - Closing up the JDBC quota store
16 Jun 09:01:01 INFO [seed.SeederThreadPoolExecutor] - Initiating shut down for running and pending seed tasks...
16 Jun 09:01:01 INFO [seed.SeederThreadPoolExecutor] - Seeder thread pool executor shut down complete.
16 Jun 09:01:01 INFO [storage.DefaultStorageBroker] - Destroying StorageBroker
16 Jun 09:01:01 WARN [support.DisposableBeanAdapter] - Destroy method 'destroy' on bean with name 'gwcMemoryBlobStore' threw an exception: java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.FutureTask@anonymised.com rejected from java.util.concurrent.ThreadPoolExecutor@anonymised.com[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 1]
16 Jun 09:01:01 WARN [support.DisposableBeanAdapter] - Invocation of destroy method failed on bean with name 'geoServerLoader': org.springframework.beans.factory.BeanCreationNotAllowedException: Error creating bean with name 'geoWebCacheExtensions': Singleton bean creation not allowed while singletons of this factory are in destruction (Do not request a bean from a BeanFactory in a destroy method implementation!)
2021-06-16 09:01:02.267:INFO:oejsh.ContextHandler:Thread-0: Stopped o.e.j.w.WebAppContext@anonymised.com{GeoServer,/geoserver,null,UNAVAILABLE}{/geoserver}
geoserver
Thanks and Regards,
Dheeraj Bharsiya,
Software Developer
Dheeraj:
Your choice of 128m is very small value for maximum java heap memory, even for GeoServer which does not load data into memory. The default of 1/4 os systems memory is appropriate for many systems; you can always try giving it a lot of memory; running your query, and checking how much memory was used using the geoserver about page.
It looks like you have the debug log level turned up, I did not see any obvious “caused by” failure in the logs you provided.
You may wish to check your posrtgresql server logs to determine the query that is being run and check how long it takes to process in order to both confirm it works and set your expectations with respect to performance.
Jody Garnett
