[Geoserver-users] Geoserver is using 100% of my CPU!
I am using Geoserver 2.7.1.1 on a Ubuntu machine. I have enabled direct
integration of GeoWebCache to generate tiles on the fly. I am following the
steps below to meet my objective of serving a large tiff image to the end
user:
1. First I have used gdal_retile to generate smaller tiles of size
(8192X8192).
2. Then created a image mosaic data store.
3. Finally I am using the openlayers to preview the tiff image.
When I try the last step, Geoserver is using more than 100% of my cpu and
stuck there for a while. But eventually it releases the CPU and generates
the GWC tiles on the fly. After checking the tomcat logs I found the
following error:
I tried to reproduce the problem on my windows desktop, but it seems to be
working fine.
What am I missing?
Thanks.
Pritimoy
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-is-using-100-of-my-CPU-tp5218417.html
On Tue, Aug 4, 2015 at 10:29 AM, prpp <pritimoy.podder@anonymised.com>
wrote:
user:
(8192X8192).
Did you generate a single level (gdal_retile is normally used to generate
pyramids)?
If so, were overviews added to the images?
You should either generate a full pyramid, and then use the image pyramid
plugin,
not image mosaic, or generate a single level set of files, add overviews to
them, and then mosaic.
You can find references and material on the subject here:
http://www.geo-solutions.it/blog/advanced-geoserver-workshops/
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Dear Andrea,
Thanks for your reply. I have generated a single level using gdal_retile
(gdal_retile.py -ps 8192 8192 -targetDir). As you suggested to add the
overviews to those tiles, I did that (gdaladdo -r average imagename 2 4 8
16 32 64 128 256 512 1024 2048 4096 8192). I can confirm that the overviews
are added to the tiff because the size has been increased significantly.
Then I used mosaic data store, still the same problem. Am I missing any
obvious advanced geoserver configuration?
Pritimoy
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-is-using-100-of-my-CPU-tp5218417p5218428.html
On Tue, Aug 4, 2015 at 12:21 PM, prpp <pritimoy.podder@anonymised.com>
wrote:
Dear Andrea,
The mosaic does not know about the overviews, you have to drop the
sample_image,
the <mosaic>.properties file, and the shapefile, clear the resource pool
caches
in GeoServer (or restart it) and then ask for that layer again, so that
the mosaic support files will be re-generated
Ing. Andrea Aime
@geowolf
Technical Lead
This presentation might give some insights:
http://goo.gl/74XUPq
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Tue, Aug 4, 2015 at 12:40 PM, Andrea Aime
wrote:
Dear Andrea,
overviews
sample_image,
caches
Ing. Andrea Aime
@geowolf
Technical Lead
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
finalità diverse, costituisce comportamento contrario ai principi dettati
dal D.Lgs. 196/2003.
information in this message that has been received in error. The sender does
Geoserver-users mailing list
Hi Andrea,
I did drop the sample_image, the <mosaic>.properties file, and the
shapefile, also restarted Geoserver, still no luck.
Pritimoy
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-is-using-100-of-my-CPU-tp5218417p5218451.html
On Tue, Aug 4, 2015 at 2:34 PM, prpp <pritimoy.podder@anonymised.com>
wrote:
Hi Andrea,
Unsure... maybe you have split the original image in too many files?
How many do you have?
As the referenced material suggests, for very large images (>100GB
uncompressed) we suggest
to use image pyramid instead
Ing. Andrea Aime
@geowolf
Technical Lead
Total 9 tiles. The original image is 855MB. FYI, I am using an AWS instance
with 4 vCPU and 7.5GiB memory for our Geoserver.
Thanks.
Pritimoy
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-is-using-100-of-my-CPU-tp5218417p5218453.html
