Hi everybody,
i published in a different layer on GeoServer and there are all visualized on layer preview with Open Layer in a correct way.
When I try to open all the layer in GeoExplorer with option (Local GeoServer) in the list of available layer I view only the first eleven (If I disable the first I visualize the 12th)
Is there a limitation of the OpenGeoSuite Community edition? Is there a configuration parameter that limit the layer numbers?
Thank’s a lot in advance
Nunzio
