[Geoserver-users] GeoServer Layer doens't visualized on GeoExplorer
On Wed, Mar 6, 2013 at 2:27 PM, Nunzio Testa <nunzio.testa@anonymised.com…> wrote:
Hi everybody,
i published in a different layer on GeoServer and there are all visualized on layer preview with Open Layer in a correct way.
When I try to open all the layer in GeoExplorer with option (Local GeoServer) in the list of available layer I view only the first eleven (If I disable the first I visualize the 12th)
Is there a limitation of the OpenGeoSuite Community edition? Is there a configuration parameter that limit the layer numbers?
The GeoServer community does not provide support for the OpenGeoSuite.
You should ask on their support forum instead:
http://getsatisfaction.com/opengeo/
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
