On Fri, Feb 12, 2016 at 1:34 PM, Sabine Ohlendorf <sabine.ohlendorf@anonymised.com..>
wrote:
Thanks for the fast reply!
I forgot to mention that I would like to have the restricted access
(certain AOI and certain time interval) for WMS requests. Does the geofence
plugin cover this?
It does. As said, you should try it out, I'm not aware of previous cases
trying to apply
the same type of security (on polygon, yes, but not on a dimension), but
yes, it should
be possible, as least in theory.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
