[Geoserver-users] Geoserver layers are not saved no error
No layers are saved when adding new. PostGis or Oracle no errors are generated. I can select the tables for publishing but when I hit the save button nothing happens… What can it be?
In the geoserver log the following:
2015-03-31 13:39:10,714 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.service.ServiceAccessRulePage/null/img/icons/silk/shape_square_key.png]
2015-03-31 13:39:10,714 DEBUG [geoserver.web] - cannot convert url: jar:file:/C:/Program%20Files/Apache%20Software%20Foundation/Tomcat%208.0/webapps/geoserver/WEB-INF/lib/gs-web-sec-core-2.5.2.jar!/org/geoserver/security/web/img/icons/silk/shape_square_key.png to file (URI is not hierarchical), falling back to the inputstream for polling
2015-03-31 13:39:10,714 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2015-03-31 13:39:10,714 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.security.web.passwd.PasswordPage/null/img/icons/silk/lock.png]
2015-03-31 13:39:10,714 DEBUG [geoserver.web] - cannot convert url: jar:file:/C:/Program%20Files/Apache%20Software%20Foundation/Tomcat%208.0/webapps/geoserver/WEB-INF/lib/gs-web-sec-core-2.5.2.jar!/org/geoserver/security/web/img/icons/silk/lock.png to file (URI is not hierarchical), falling back to the inputstream for polling
2015-03-31 13:39:10,730 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/ajax-loader.gif]
2015-03-31 13:39:10,730 DEBUG [geoserver.web] - cannot convert url: jar:file:/C:/Program%20Files/Apache%20Software%20Foundation/Tomcat%208.0/webapps/geoserver/WEB-INF/lib/gs-web-core-2.5.2.jar!/org/geoserver/web/img/ajax-loader.gif to file (URI is not hierarchical), falling back to the inputstream for polling
2015-03-31 13:39:10,730 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
2015-03-31 13:39:10,933 TRACE [ows.OWSHandlerMapping] - No handler mapping found for [/web/resources/org.geoserver.web.GeoServerBasePage/img/button-gradient.png]
2015-03-31 13:39:10,933 DEBUG [geoserver.web] - cannot convert url: jar:file:/C:/Program%20Files/Apache%20Software%20Foundation/Tomcat%208.0/webapps/geoserver/WEB-INF/lib/gs-web-core-2.5.2.jar!/org/geoserver/web/img/button-gradient.png to file (URI is not hierarchical), falling back to the inputstream for polling
2015-03-31 13:39:10,933 DEBUG [filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
Met vriendelijke groet,
Erik-Jan Martens
Geo-informatiebeheerder
GRSK- SSC de Kempen
Tel.: 0497551489
Email: e.martens@anonymised.com
Hi Erik,
could it be some incompatibility of the GeoServer UI with your browser? Could you try to do the same thing using a different one?
Mauro
2015-03-31 13:46 GMT+02:00 Erik Jan Martens <E.Martens@anonymised.com>:
Erik-Jan Martens
GRSK- SSC de Kempen
Tel.: 0497551489
Email: e.martens@anonymised.com88…
Op dit bericht is een disclaimer van toepassing. De volledige tekst vindt u op:
http://www.kempengemeenten.nl/maildisclaimer
Dive into the World of Parallel Programming The Go Parallel Website, sponsored
by Intel and developed in partnership with Slashdot Media, is your hub for all
things parallel software development, from weekly thought leadership blogs to
news, videos, case studies, tutorials and more. Take a look and join the
conversation now. http://goparallel.sourceforge.net/
Geoserver-users mailing list
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via Poggio alle Viti 1187
Hi Mauro.
It was the solution. Thanks a lot. Where could I have found a compatibilitylist?
Erik-Jan Martens
GRSK- SSC de Kempen
Tel.: 0497551489
Email: e.martens@…6988…
Verzonden: dinsdag 31 maart 2015 14:38
Hi Erik,
Mauro
2015-03-31 13:46 GMT+02:00 Erik Jan Martens <E.Martens@…6988…>:
Erik-Jan Martens
GRSK- SSC de Kempen
Tel.: 0497551489
@mauro_bart
Hi Erik,
2015-03-31 15:16 GMT+02:00 Erik Jan Martens <E.Martens@anonymised.com>:
Hi Mauro.
An official list of compatible browser does not exist, but in the past I experienced your same symptoms (buttons, links not doing anything) and it was a matter of browser / wicket incompatibilities. Wicket is the library used to develop the GeoServer UI. These type of issues have been resolved by newer GeoServer versions when reported. Which version of GeoServer are you using and which browser is giving you problems?
Mauro
@mauro_bart
I’m using IE 11 and Geoserver 2.5.2.
Erik-Jan Martens
GRSK- SSC de Kempen
Tel.: 0497551489
Verzonden: dinsdag 31 maart 2015 15:36
Hi Erik,
2015-03-31 15:16 GMT+02:00 Erik Jan Martens <E.Martens@…6988…>:
Hi Mauro.
Mauro
@mauro_bart
Hi Erik,
probably this is the issue: https://jira.codehaus.org/browse/GEOS-6426
From the JIRA seems to solved from 2.5.4.
Mauro
2015-03-31 15:45 GMT+02:00 Erik Jan Martens <E.Martens@anonymised.com>:
Erik-Jan Martens
GRSK- SSC de Kempen
Tel.: 0497551489
Van: Mauro Bartolomeoli [mailto:mauro.bartolomeoli@anonymised.com]
Aan: Erik Jan Martens
CC: Mauro Bartolomeoli; geoserver-users@lists.sourceforge.net
Onderwerp: Re: [Geoserver-users] Geoserver layers are not saved no error
Hi Erik,
Hi Mauro.
Mauro
@mauro_bart
@mauro_bart
