[Geoserver-users] Geoserver leaves idle connections to Postgresql
I’m using GeoServer 2.7.7, with JVM version 1.7.0_65 (OpenJDK 64-Bit Server VM). I’m also using Postgresql server version 9.2.0.
The problem is that when I open the Layer Preview and I visualize a layer with OpenLayers I see new open connection to Postgresql DB that stay in IDLE status.
The problem is the same when I upload into geoserver new layers.
I also set up a JNDI connection pool but the problem still remains.
Does anyone knows why?
Thank you for your help.
Best regards,
Matteo.
On Tue, Feb 2, 2016 at 10:04 AM, matteo rivola <mrganesh86@anonymised.com> wrote:
I'm using GeoServer 2.7.7, with JVM version 1.7.0_65 (OpenJDK 64-Bit
Server VM). I'm also using Postgresql server version 9.2.0.
IDLE status.
Because that's what a connection pool is designed to do, keep connections
open so
that the next request does not have to pay the price of creating a new one
every time.
https://en.wikipedia.org/wiki/Connection_pool
You can tune the parameters of the pool to keep the connections alive for
less time,
of course that might have a negative effect on performance
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
less time,
Matteo,
why do you want database connections shut down?
This example from app-schema has been configured to shut down all connections after ten minutes to protect against firewalls that sever connections, but you may be able to use a similar configuration if you have a need to do the same:
http://docs.geoserver.org/latest/en/user/data/app-schema/data-stores.html#jndi
Here is the main JNDI page:
http://docs.geoserver.org/latest/en/user/tutorials/tomcat-jndi/tomcat-jndi.html
Kind regards,
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
Dear all,
I want to thank you for your prompt reply.
Probably I didn’t explayn well my problem.
I know that Geoserver open a connection pool with the DB, so the connection has to stay open. Also I have configured JNDI in the same way explained in the Geoserver docs.
The problem is that in my system the connections in idle grow up untill the DB can not handle.
I set up the parameter “maxIdle” in the server.xml file but it doesn’t work.
Thank you for your patience and cooperation.
Best regards,
Matteo.
2016-02-05 20:37 GMT+01:00 Ben Caradoc-Davies <ben@anonymised.com>:
less time,
Matteo,
Kind regards,
Director
Transient Software Limited <http://transient.nz/>
New Zealand
