[Geoserver-users] Geoserver login problem
I want to use Geoserver with Cartaro Geospatial CMS
<http://cartaro.org/overview&gt;
First I login using USERNAME : /admin/ and PASSWORD / geoserver/
The next time I can't login using /admin/ and /geoserver/.
I reinstall Geoserver, I set my own username and password, but it seems
that Geoserver forgets username and password, and I can't login.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-login-problem-tp5127912.html
Please try a stand-alone GeoServer and see if you can reproduce the problem.
If you cannot, ask for support on the Cartaro community (not sure if they
have a forum/mailing list) and see if they can give you more details
== Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
@geowolf thanks for your reply.
Ι try binary format of Geoserver 2.4.5 from here
http://geoserver.org/display/GEOS/Stable
<http://geoserver.org/display/GEOS/Stable&gt;
The problem remains.
Another problem occurs during Cartaro <http://cartaro.org/&gt; installation,
it couldn't create Geoserver workspace.
I found a topic about this problem in Drupal forum
<https://drupal.org/node/1822002&gt; , but it didn't help me.
Is there a relationship between these problems?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-login-problem-tp5127912p5127923.html
So you try to login directly in GeoServer (not via cartaro, not using
any cartaro related plugin) and it does not work?
What happens?
installation,
Looking at the thread above it seems one has to install some Drupal
authentication
plugin that is not maintained by the GeoServer community, I guess it is
coded
and shipped by the Cartaro team? If so, you should ask there, as far as I
know,
none of the GeoServer developers is involved in Cartaro (so, none of them
will be able to help you).
more information ==
Ing. Andrea Aime
@geowolf
Technical Lead
It is weird, but I can't login directly to geoserver-2.4.5 (web archive) as
admin from web browser UI (localhost:8080/geoserver).
As I said before I had problems during Cartaro installation and I want to
change Role Services and Authentication Provider as admin. (I can login as
admin only the first time)
I put geoserver.war into /var/lib/tomcat7/webapps.
I add the JVM startup parameter ENABLE_JSONP=true in /etc/default/tomcat7.
Also, I try the binary format of geoserver but the problem remains.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-login-problem-tp5127912p5127967.html
From your report I can't tell if the issue is in GeoServer, in Cartaro, or
in
the integration between the two.
Do you have anything in the GeoServer logs?
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
