I have loaded up millions of points representing facilities, for multiple
program systems with differing attribute characteristics for each program
into PostGIS and served them through GeoServer, am very happy with the
results - agree, spatial indexing is crucial, you may also want to look at
database clustering.
David G. Smith PE PLS
Synergist Technology Group, Inc.
570.280.6763
NOTE: New cell phone number:
570-280-6763
-----Original Message-----
From: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Sent: Sunday, October 26, 2008 1:45 PM
To: James Cauchi
Subject: Re: [Geoserver-users] GeoServer & Many Points
Hi James,
So yeah, you definitely want to install postgis, and then store your
points as spatial objects. You also want to create a spatial index on
the geometry column. With a spatial index you should have no problem
storing millions of points and displaying them very quickly.
Its also straight forward to achieve the click and get info
functionality with openlayers and GeoServer. If you run Geoserver and
check out the openlayers map preview, you will see how this works.
Hope that helps.
-Justin
James Cauchi wrote:
Hi GeoServer Community,
My Question:
What is the best way to store and serve a large # (> 10000) of point
objects with different properties.
Background:
I am seeking design advice as to how to store and serve these points.
I am using GeoServer 1.6.5 and OpenLayers.
My Point objects are currently stored in a Postgres table.
The table is updated daily.
I have created a layer in OpenLayers using javascript from the result
of a postgres query but this is very slow when there are many points
as you can imagine.
I would also like to attach descriptors to the points so that the user
is able to click on it and get more info.
Another feature would be to change their size and colour based on a
value from the db.
Finally I want to attach different markers to each point based on bearing.
I was thinking of installing PostGis - and create a coverage in
GeoServer pointing to the PostGis db directly.
Any ideas or experiences are welcome.
Best Regards
James
This SF.Net email is sponsored by the Moblin Your Move Developer's
challenge
Build the coolest Linux based applications with Moblin SDK & win great
prizes
Grand prize is a trip for two to an Open Source event anywhere in the
world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
