[Geoserver-users] geoserver maven build error
I use the win xp system,had downloaded the resources from the geoserver web site,since I have install the maven before then I directly run the command “mvn install” for the project ,but error always occured.This is the message:
Results :
Tests in error:
testHandleServiceException(org.geoserver.ows.DefaultServiceExceptionHandlerTest)
testHandleServiceExceptionCauses(org.geoserver.ows.DefaultServiceExceptionHandlerTest)
Tests run: 21, Failures: 0, Errors: 2, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to C:\Documents and Settings\Administrator\桌面\geoserver-1.7.3-src\geoserver-1.7.3\ows
\target\surefire-reports for the individual test results.
[INFO] Total time: 31 minutes 52 seconds
[INFO] Finished at: Wed Mar 25 11:28:39 CST 2009
[INFO] Final Memory: 33M/63M
Is there anyone came the problem before??
Hmmm... strange. What version of the source code are you running? Also it might help if you could include the test log from
ows/target/surefire-reports for the failed tests.
-Justin
apachemaven wrote:
I use the win xp system,had downloaded the resources from the geoserver web site,since I have install the maven before then I directly run the command "mvn install" for the project ,but error always occured.This is the message:
Results :
Tests in error:
Please refer to C:\Documents and Settings\Administrator\×ÀÃæ\geoserver- 1.7.3-src\geoserver-1.7.3\ows
Apps built with the Adobe(R) Flex(R) framework and Flex Builder(TM) are
powering Web 2.0 with engaging, cross-platform capabilities. Quickly and
easily build your RIAs with Flex Builder, the Eclipse(TM)based development
software that enables intelligent coding and step-through debugging.
Download the free 60 day trial. http://p.sf.net/sfu/www-adobe-com
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
to Justin Deoliveira:
under the ows/target there is only two folder:classes and test-classes
在2009-03-28 04:18:56,"Justin Deoliveira" <jdeolive@anonymised.com> 写道:
>(please keep replies on the public list).
>The files in question are under the root of the source tree, so should
>be under:
>geoserver-1.7.0/ows/target/surefire-reports
>And then look for the file:
>org.geoserver.ows.DefaultServiceExceptionHandlerTest.txt
>-Justin
>apachemaven wrote:
>> Hi,the verison is 1.7,and I can not find the file what you mentioned....
>> 在2009-03-26 23:32:43,"Justin Deoliveira" <jdeolive@anonymised.com> 写道:
>>>-Justin
>>>> the message:
>>>> Results :
>>>> Tests in error:
>>>> [INFO]
>>>> [INFO]
>>>> [INFO]
>>>> [INFO]
>>>> [INFO]
>>>> _______________________________________________
>>>> Geoserver-users@lists.sourceforge.net
>>>> https://lists.sourceforge.net/lists/listinfo/geoserver-users
>>>Justin Deoliveira
>Justin Deoliveira
Anytime tests are run by maven, the directory target/surefire-reports should be created.
So my guess is perhaps you did a clean in the interim. I would do the following:
cd ows
mvn clean install
ls target/surefire-reports
-Justin
ÔÚ2009-03-28 04:18:56£¬"Justin Deoliveira" <jdeolive@anonymised.com> дµÀ£º
The files in question are under the root of the source tree, so should be under:
-Justin
ÔÚ2009-03-26 23:32:43£¬"Justin Deoliveira" <jdeolive@anonymised.com> дµÀ£º
-Justin
Results :
Tests in error:
Justin Deoliveira
Justin Deoliveira
Justin Deoliveira
