On Thu, Apr 25, 2013 at 2:52 PM, gabriel <gpetricek@anonymised.com> wrote:
im working with monitoring hibernate extension. Database for output
informations is set to H2 database. When I try to read the H2 files with
RazorSQL, it says:
Unsupported database file version or invalid file header in file "Old
database:
C:/Program Files (x86)/GeoServer
2.3.1/data_dir/monitoring/monitoring.data.db
- please convert the database to a SQL script
and re-create it." [90048-166]
The same problem was , when i tried to open the monitoring.data.db file
with
OpenOffice or attach it to H2 database.
Did someone have experience with this problem ?
Never tried to read the H2 databases with anything other than SquirrelSQL
using the same driver jar GeoServer uses, which of course works, but
we are indeed using a rather old version of H2.
Upgrading it to a more recent version is not exactly an easy task, as we
need to upgrade at the same time GeoTools, GeoWebCache and GeoServer,
plus, hard to get the right version, the db format changed a few times, if
we pick a too recent one those tools might not be able to open it for
the opposite issue (too new of a format)
GeoServer training in Milan, 6th & 7th June 2013! Visit
http://geoserver.geo-solutions.it for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
