[Geoserver-users] Geoserver + Mr.Sid
Hello
I am newbie in regard to geoserver and we are implementing geoserver in our test environment initially. We have Mr.Sid imagery and would like to load them in geoserver. But we are not able to do so as support for Mr.sid is not available , would appreciate any help or directions in this regard.
We are using:
Ubuntu 12.04 LTS
Geoserver 2.5
And some of the information about our setup
geoserver-test:~# gdalinfo --version
GDAL 1.7.3, released 2010/11/10
geoserver-test:~# gcc --version
gcc (Ubuntu/Linaro 4.6.3-1ubuntu5) 4.6.3
Copyright (C) 2011 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
geoserver-test:~# locate libgdal
/lib/libgdal.so
/lib/libgdal.so.1
/lib/libgdal.so.1.16.2
/lib/libgdalconstjni.so
/lib/libgdalconstjni.so.1
/lib/libgdaljni.so
/lib/libgdaljni.so.1
/opt/gdallib/libgdal.so
/opt/gdallib/libgdal.so.1
/opt/gdallib/libgdal.so.1.16.2
/opt/gdallib/libgdalconstjni.so
/opt/gdallib/libgdaljni.so
/root/libgdal-mrsid-src_1.9.0-2~oneiric1_all.deb
/usr/lib/libgdal.so.1
/usr/lib/libgdal.so.1.16.2
/usr/lib/libgdal1.7.0.a
/usr/lib/libgdal1.7.0.so
/usr/lib/libgdal1.7.0.so.1
/usr/lib/libgdal1.7.0.so.1.14.3
/usr/lib/jvm/java-7-oracle/jre/lib/amd64/libgdal.so
/usr/lib/jvm/java-7-oracle/jre/lib/amd64/libgdal.so.1
/usr/lib/jvm/java-7-oracle/jre/lib/amd64/libgdal.so.1.16.2
/usr/lib/jvm/java-7-oracle/jre/lib/amd64/libgdalconstjni.so
/usr/lib/jvm/java-7-oracle/jre/lib/amd64/libgdaljni.so
/usr/lib/ogdi/libgdal.so
/usr/share/doc/libgdal1
/usr/share/doc/libgdal1-1.7.0
/usr/share/doc/libgdal1-dev
/usr/share/doc/libgdal1-1.7.0/NEWS.Debian.gz
/usr/share/doc/libgdal1-1.7.0/NEWS.gz
/usr/share/doc/libgdal1-1.7.0/TODO.Debian
/usr/share/doc/libgdal1-1.7.0/changelog.Debian.gz
/usr/share/doc/libgdal1-1.7.0/copyright
/usr/share/lintian/overrides/libgdal1
/usr/share/lintian/overrides/libgdal1-1.7.0
/var/cache/apt/archives/libgdal1-1.7.0_1.7.3-6ubuntu3_amd64.deb
/var/cache/apt/archives/libgdal1-dev_1.7.3-6ubuntu3_amd64.deb
/var/cache/apt/archives/libgdal1_1.9.2-2~precise4_amd64.deb
/var/lib/dpkg/info/libgdal1-1.7.0.list
/var/lib/dpkg/info/libgdal1-1.7.0.md5sums
/var/lib/dpkg/info/libgdal1-1.7.0.postinst
/var/lib/dpkg/info/libgdal1-1.7.0.postrm
/var/lib/dpkg/info/libgdal1-1.7.0.shlibs
/var/lib/dpkg/info/libgdal1-dev.list
/var/lib/dpkg/info/libgdal1-dev.md5sums
/var/lib/dpkg/info/libgdal1.list
/var/lib/dpkg/info/libgdal1.md5sums
/var/lib/dpkg/info/libgdal1.postinst
/var/lib/dpkg/info/libgdal1.postrm
/var/lib/dpkg/info/libgdal1.shlibs
/var/lib/dpkg/info/libgdal1.symbols
ps aux | grep java
tomcat7 18513 2.6 8.1 6666292 999392 ? Sl 11:20 1:44 /usr/lib/jvm/java-1.7.0-openjdk-amd64/bin/java -Djava.util.logging.config.file=/var/lib/tomcat7/conf/logging.properties -server -Dfile.encoding=UTF-8 -Xms2048m -Xmx2048m -XX:PermSize=2048m -XX:MaxPermSize=2048m -XX:+UseParallelGC -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager -server -Dfile.encoding=UTF-8 -Xms2048m -Xmx2048m -XX:PermSize=2048m -XX:MaxPermSize=2048m -XX:+UseParallelGC -Djava.endorsed.dirs=/usr/share/tomcat7/endorsed -classpath /usr/share/tomcat7/bin/bootstrap.jar:/usr/share/tomcat7/bin/tomcat-juli.jar -Dcatalina.base=/var/lib/tomcat7 -Dcatalina.home=/usr/share/tomcat7 -Djava.io.tmpdir=/tmp/tomcat7-tomcat7-tmp org.apache.catalina.startup.Bootstrap start
root 19413 0.0 0.0 9388 940 pts/0 S+ 12:26 0:00 grep --color=auto java
geoserver-test:~# gdalinfo --formats
Supported Formats:
VRT (rw+v): Virtual Raster
GTiff (rw+v): GeoTIFF
NITF (rw+v): National Imagery Transmission Format
RPFTOC (ro): Raster Product Format TOC format
HFA (rw+v): Erdas Imagine Images (.img)
SAR_CEOS (ro): CEOS SAR Image
CEOS (ro): CEOS Image
JAXAPALSAR (ro): JAXA PALSAR Product Reader (Level 1.1/1.5)
GFF (rov): Ground-based SAR Applications Testbed File Format (.gff)
ELAS (rw+): ELAS
AIG (ro): Arc/Info Binary Grid
AAIGrid (rwv): Arc/Info ASCII Grid
SDTS (ro): SDTS Raster
OGDI (ro): OGDI Bridge
DTED (rwv): DTED Elevation Raster
PNG (rwv): Portable Network Graphics
JPEG (rwv): JPEG JFIF
MEM (rw+): In Memory Raster
JDEM (ro): Japanese DEM (.mem)
GIF (rwv): Graphics Interchange Format (.gif)
BIGGIF (rov): Graphics Interchange Format (.gif)
ESAT (ro): Envisat Image Format
BSB (ro): Maptech BSB Nautical Charts
XPM (rw): X11 PixMap Format
BMP (rw+v): MS Windows Device Independent Bitmap
DIMAP (ro): SPOT DIMAP
AirSAR (ro): AirSAR Polarimetric Image
RS2 (ro): RadarSat 2 XML Product
PCIDSK (rw+v): PCIDSK Database File
PCRaster (rw): PCRaster Raster File
ILWIS (rw+v): ILWIS Raster Map
SGI (rw+): SGI Image File Format 1.0
SRTMHGT (rwv): SRTMHGT File Format
Leveller (rw+): Leveller heightfield
Terragen (rw+): Terragen heightfield
GMT (rw): GMT NetCDF Grid Format
netCDF (rw): Network Common Data Format
HDF4 (ro): Hierarchical Data Format Release 4
HDF4Image (rw+): HDF4 Dataset
ISIS3 (ro): USGS Astrogeology ISIS cube (Version 3)
ISIS2 (ro): USGS Astrogeology ISIS cube (Version 2)
PDS (ro): NASA Planetary Data System
TIL (ro): EarthWatch .TIL
ERS (rw+): ERMapper .ers Labelled
JPEG2000 (rwv): JPEG-2000 part 1 (ISO/IEC 15444-1)
L1B (ro): NOAA Polar Orbiter Level 1b Data Set
FIT (rw): FIT Image
GRIB (ro): GRIdded Binary (.grb)
RMF (rw+): Raster Matrix Format
WCS (ro): OGC Web Coverage Service
WMS (ro): OGC Web Map Service
MSGN (ro): EUMETSAT Archive native (.nat)
RST (rw+): Idrisi Raster A.1
INGR (rw+): Intergraph Raster
GSAG (rw): Golden Software ASCII Grid (.grd)
GSBG (rw+): Golden Software Binary Grid (.grd)
GS7BG (ro): Golden Software 7 Binary Grid (.grd)
COSAR (ro): COSAR Annotated Binary Matrix (TerraSAR-X)
TSX (ro): TerraSAR-X Product
COASP (ro): DRDC COASP SAR Processor Raster
R (rwv): R Object Data Store
PNM (rw+): Portable Pixmap Format (netpbm)
DOQ1 (ro): USGS DOQ (Old Style)
DOQ2 (ro): USGS DOQ (New Style)
ENVI (rw+v): ENVI .hdr Labelled
EHdr (rw+v): ESRI .hdr Labelled
GenBin (ro): Generic Binary (.hdr Labelled)
PAux (rw+): PCI .aux Labelled
MFF (rw+): Vexcel MFF Raster
MFF2 (rw+): Vexcel MFF2 (HKV) Raster
FujiBAS (ro): Fuji BAS Scanner Image
GSC (ro): GSC Geogrid
FAST (ro): EOSAT FAST Format
BT (rw+): VTP .bt (Binary Terrain) 1.3 Format
LAN (ro): Erdas .LAN/.GIS
CPG (ro): Convair PolGASP
IDA (rw+): Image Data and Analysis
NDF (ro): NLAPS Data Format
EIR (ro): Erdas Imagine Raw
DIPEx (ro): DIPEx
LCP (rov): FARSITE v.4 Landscape File (.lcp)
RIK (ro): Swedish Grid RIK (.rik)
USGSDEM (rw): USGS Optional ASCII DEM (and CDED)
GXF (ro): GeoSoft Grid Exchange Format
DODS (ro): DAP 3.x servers
HTTP (ro): HTTP Fetching Wrapper
BAG (ro): Bathymetry Attributed Grid
HDF5 (ro): Hierarchical Data Format Release 5
HDF5Image (ro): HDF5 Dataset
NWT_GRD (ro): Northwood Numeric Grid Format .grd/.tab
NWT_GRC (ro): Northwood Classified Grid Format .grc/.tab
ADRG (rw+v): ARC Digitized Raster Graphics
SRP (rov): Standard Raster Product (ASRP/USRP)
BLX (rw): Magellan topo (.blx)
Rasterlite (rw): Rasterlite
EPSILON (rwv): Epsilon wavelets
WKTRaster (ro): PostGIS WKT Raster driver
SAGA (rw+v): SAGA GIS Binary Grid (.sdat)
Thanks and regards
-Aslam
There are some instructions in the manual: http://docs.geoserver.org/stable/en/user/data/raster/gdal.html
Note that ECW is a non open source format and thus a license is required for that library.
ยทยทยท
Jody Garnett
On Tue, Apr 22, 2014 at 6:15 PM, Muhammad Aslam <aslam.popal@anonymised.com> wrote:
Hello
We are using:
Ubuntu 12.04 LTS
Geoserver 2.5
/lib/libgdal.so
/lib/libgdal.so.1
/lib/libgdaljni.so
ps aux | grep java
Supported Formats:
ELAS (rw+): ELAS
FIT (rw): FIT Image
DIPEx (ro): DIPEx
Thanks and regards
-Aslam
Start Your Social Network Today - Download eXo Platform
Build your Enterprise Intranet with eXo Platform Software
Java Based Open Source Intranet - Social, Extensible, Cloud Ready
Get Started Now And Turn Your Intranet Into A Collaboration Platform
http://p.sf.net/sfu/ExoPlatform
Geoserver-users mailing list
