[Geoserver-users] Geoserver new version installation - SOLVED
I rebooted the server a couple of times and the problem persisted. Then, all of a sudden it started to work. I reviewed completely the log files before and after, and they are the same with exactly same messages.
I am posting this because it might happen with other people.
Cheers.
JJ.
From: Jair Santos [mailto:jsantos5954@anonymised.com…]
Sent: Friday, October 09, 2015 1:13 PM
To: ‘GeoServer Mailing List List’ geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] Geoserver new version installation
Hello,
I installed Geoserver 2.8 copying the war file to C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps.
It successfully ran and I was able to create workspace, store and layers.
When I tried the layer preview it failed. I couldn’t see any layer including the ones that I’ve just created.
The environment variables are:
GEOSERVER_DATA_DIR C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\geoserver\data
GEOSERVER_HOME C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps
Please see below what I’ve found in the log file.
Thank you for any help.
JJ.
2015-10-09 12:55:28,996 WARN [geoserver.security] - Strong cryptography is NOT available
Download and installation the of unlimted length policy files is recommended
2015-10-09 12:53:27,828 INFO [layer.TileLayerDispatcher] - Configuration C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\geoserver\data\gwc contained no layers.
2015-10-09 12:53:25,862 WARN [imagemosaic.Utils] - Unable to find sample image for path C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\geoserver\data\coverages\mosaic_sample\sample_image
2015-10-09 12:53:25,862 WARN [gce.imagemosaic] - Unable to find sample image for path file:/C:/Program%20Files/Apache%20Software%20Foundation/Tomcat%208.0/webapps/geoserver/data/coverages/mosaic_sample/mosaic.shp
2015-10-09 12:55:32,795 WARN [geoserver.web] - Unable to find property: ‘format.wms.application/vnd.google-earth.kml’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2015-10-09 12:55:32,802 WARN [geoserver.web] - Unable to find property: ‘format.wms.rss’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2015-10-09 12:53:27,953 INFO [diskquota.ConfigLoader] - DiskQuota configuration not found: C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\geoserver\data\gwc\geowebcache-diskquota.xml
2015-10-09 12:53:27,984 INFO [diskquota.ConfigLoader] - DiskQuota configuration not found: C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\geoserver\data\gwc\geowebcache-diskquota.xml
2015-10-09 12:53:28,000 INFO [diskquota.DiskQuotaMonitor] - Setting up disk quota periodic enforcement task
Yes, GeoServer 2.7 and 2.8 should work fine with Java 8 too
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
