[Geoserver-users] Geoserver new version installation
Hello all,
I figure that in order to solve the CORS problem that I am facing, I'll need
to re-install GeoServer inside jetty. Therefore, since I'll need to remove
it, I better install the new 2.8.0 version with the Platform Independent
Binary.
I'll appreciate very much some advices about the best way of doing that. One
of the questions that I have is about Java. For the 2.8.0 geoserver version
can I install the latest Java? Or I still should use the JRE7?
Please, provide me with any tips you might have for this procedure.
TIA
JJ.
Hi Jair,
the installer version and the bin version both contain a very old Jetty, for which finding
procedures for CORS might be difficult.
I’d suggest you install Tomcat instead, and deploy the GeoServer WAR file into it
instead: it’s the recommended production approach.
On Thu, Oct 8, 2015 at 11:40 PM, Jair Santos <jsantos5954@anonymised.com> wrote:
Hello all,
I figure that in order to solve the CORS problem that I am facing, I’ll need
to re-install GeoServer inside jetty. Therefore, since I’ll need to remove
Binary.
I’ll appreciate very much some advices about the best way of doing that. One
TIA
JJ.
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thank you Andrea.
I will do it.
I read somewhere that for the new Geoserver version it is possible to use the latest Java. Could you please confirm?
Thanks.
JJ.
From: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] On Behalf Of Andrea Aime
Sent: Thursday, October 08, 2015 11:21 PM
To: Jair Santos <jsantos5954@anonymised.com4…>
Cc: GeoServer Mailing List List geoserver-users@anonymised.coms.sourceforge.net
Subject: Re: [Geoserver-users] Geoserver new version installation
Hi Jair,
On Thu, Oct 8, 2015 at 11:40 PM, Jair Santos <jsantos5954@…84…> wrote:
Hello all,
Binary.
TIA
JJ.
Ing. Andrea Aime
@geowolf
Technical Lead
On Fri, Oct 9, 2015 at 5:43 PM, Jair Santos <jsantos5954@anonymised.com> wrote:
Thank you Andrea.
I will do it.
Yes, GeoServer 2.7 and 2.8 should work fine with Java 8 too
Ing. Andrea Aime
@geowolf
Technical Lead
Hello,
I installed Geoserver 2.8 copying the war file to C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps.
It successfully ran and I was able to create workspace, store and layers.
When I tried the layer preview it failed. I couldn’t see any layer including the ones that I’ve just created.
The environment variables are:
GEOSERVER_DATA_DIR C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\geoserver\data
GEOSERVER_HOME C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps
Please see below what I’ve found in the log file.
Thank you for any help.
JJ.
2015-10-09 12:55:28,996 WARN [geoserver.security] - Strong cryptography is NOT available
Download and installation the of unlimted length policy files is recommended
2015-10-09 12:53:27,828 INFO [layer.TileLayerDispatcher] - Configuration C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\geoserver\data\gwc contained no layers.
2015-10-09 12:53:25,862 WARN [imagemosaic.Utils] - Unable to find sample image for path C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\geoserver\data\coverages\mosaic_sample\sample_image
2015-10-09 12:53:25,862 WARN [gce.imagemosaic] - Unable to find sample image for path file:/C:/Program%20Files/Apache%20Software%20Foundation/Tomcat%208.0/webapps/geoserver/data/coverages/mosaic_sample/mosaic.shp
2015-10-09 12:55:32,795 WARN [geoserver.web] - Unable to find property: ‘format.wms.application/vnd.google-earth.kml’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2015-10-09 12:55:32,802 WARN [geoserver.web] - Unable to find property: ‘format.wms.rss’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2015-10-09 12:53:27,953 INFO [diskquota.ConfigLoader] - DiskQuota configuration not found: C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\geoserver\data\gwc\geowebcache-diskquota.xml
2015-10-09 12:53:27,984 INFO [diskquota.ConfigLoader] - DiskQuota configuration not found: C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\geoserver\data\gwc\geowebcache-diskquota.xml
2015-10-09 12:53:28,000 INFO [diskquota.DiskQuotaMonitor] - Setting up disk quota periodic enforcement task
Ing. Andrea Aime
@geowolf
Technical Lead
