[Geoserver-users] Geoserver on a Microsoft Windows Server 2003
Is there any documentation, or has anyone successfully installed Geoserver on a Microsoft Windows Server 2003 machine as a service. I would like the application to run at all times, regardless of myself being active or logged into the application server. I have currently tried to schedule the start of the Geoserver application as a start-up task, but it is not functioning. Any suggestions are welcome. Thank you.
Terrence A. Pietrondi
terrence_a_pietrondi@anonymised.com
This communication may contain privileged and/or confidential information. It
is intended solely for the use of the addressee. If you are not the intended
recipient, you are strictly prohibited from disclosing, copying, distributing
or using any of this information. If you received this communication in error,
please contact the sender immediately and destroy the material in its entirety,
whether electronic or hard copy. This communication may contain nonpublic personal
information about consumers subject to the restrictions of the
Gramm-Leach-Bliley Act. You may not directly or indirectly reuse or redisclose
such information for any purpose other than to provide the services for which
you are receiving the information.
127 Public Square, Cleveland, OH 44114
If you prefer not to receive future e-mail offers for products or services from
Key send an e-mail to DNERequests@anonymised.com with 'No Promotional E-mails' in the
SUBJECT line.
SUBJECT line.
SUBJECT line.
Hi Terrence,
This was actually just recently discussed in teh following thread:
http://www.nabble.com/geoserver-as-windows-service-and-administration-t3876724.html
But the info you need should be here:
http://docs.codehaus.org/display/GEOSDOC/Windows+Service+Wrapper
-Justin
SUBJECT line.
SUBJECT line.
SUBJECT line.
!DSPAM:4007,466f4ddf81261804284693!
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
Geoserver-users mailing list
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Also check out our page on advice for running GeoServer in production: http://docs.codehaus.org/display/GEOSDOC/4+GeoServer+in+Production+Environment
I'd recommend installing tomcat and using the GeoServer war, as it's very well set up to run as a service - they've put a lot of great work in to making it do a great job there.
Justin Deoliveira wrote:
Hi Terrence,
-Justin
information about consumers subject to the restrictions of the Gramm-Leach-Bliley Act. You may not directly or indirectly reuse or redisclose
SUBJECT line.
SUBJECT line.
SUBJECT line.
Chris Holmes
http://topp.openplans.org
