[Geoserver-users] GeoServer on Java 8 VM
I’m doing testing on how GeoServer runs on Java 8 (Although compiled with Java 7). As yet I’m not seeing any issues, including when I run the unit tests for the release profile. I’ll be throwing some automated stress tests at it today.
There’s no particular reason to expect this to be problematic but I’d like to confirm so does anyone have any experience running in Java 8, be it an interesting a failure or a boring success? Especially if it was in production or involved any attempt to do thorough testing.
I know the topic of running on Java 8 has come up before I expect we won’t fully lay it to rest until we can build reliably under Java 8, but I would like to get something a bit more solid than “it should work” or “it seems to work”.
Kevin Smith
Software Engineer | Boundless
ksmith@anonymised.com
+1-778-785-7459
@boundlessgeo
http://boundlessgeo.com/
Boring Success here
I’ve been running java 8 since 2.6 on my live windows server 8 r2 – my server guys don’t like me using old java software
No issues
I am running 2.7.0 at the moment
Mark Ismail
Sent: 10 June 2015 19:52
Subject: [Geoserver-users] GeoServer on Java 8 VM
Kevin Smith
ksmith@…5876…
+1-778-785-7459
@boundlessgeo
None of my stress tests managed to break things either. So boring successes all around.
On 11 June 2015 at 01:07, Ismail, Mark <mark.ismail@anonymised.com> wrote:
Boring Success here
No issues
Mark Ismail
Kevin Smith
+1-778-785-7459
@boundlessgeo
This e-mail and any attachments are confidential. It may contain privileged information and is intended for the named recipient(s) only. It must not be distributed without consent. If you are not one of the intended recipients, please notify the sender immediately and do not disclose, distribute, or retain this email or any part of it and do not take any action based on it.
Unless expressly stated, opinions in this email are those of the individual sender, and not of Knowsley MBC. Legally binding obligations can only be created for, or be entered into on behalf of, Knowsley MBC by duly authorised officers or representatives.
Knowsley MBC excludes any liability whatsoever for any offence caused, any direct or consequential loss arising from the use, or reliance on, this e-mail or its contents. We believe but do not warrant that this e-mail and any attachments are virus free. You must therefore take full responsibility for virus checking and no responsibility is accepted for loss or damage arising from viruses or changes made to this message after it was sent. Knowsley MBC reserves the right to monitor and/or record all e-mail communications through its network in accordance with relevant legislation.
Geoserver-users mailing list
Kevin Smith
+1-778-785-7459
@boundlessgeo
