I am trying to deploy the geoserver war file into Tomcat 5.5 running on Ubuntu. The standalone geoserver version works fine in its own directory, but when I try to deploy the war file, it fails trying to startup the /geoserver path in Tomcat manager. The following lines in tomcat log appear to point out some kind of permission issue (bold line below), but I cannot figure out why or how to solve it:
GRAVE: Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘validation’ defined in URL [jar:file:/var/lib/tomcat5/webapps/geoserver/WEB-INF/lib/validation-1.4.0.jar!/applicationContext.xml]: Can’t resolve reference to bean ‘config’ while setting property ‘constructor argument’; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘config’ defined in URL [jar:file:/var/lib/tomcat5/webapps/geoserver/WEB-INF/lib/main-1.4.0.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is org.springframework.beans.factory.BeanInitializationException: Error creating xml config reader; nested exception is org.vfny.geoserver.global.ConfigurationException: java.security.AccessControlException: access denied (java.lang.RuntimePermission preferences)
Any suggestion would be much appreciated, thank you.
Do you have any data in there? Is the catalog.xml present?
Alex
Error creating bean with name 'validation' defined in URL
Can't resolve reference to bean 'config' while setting property 'constructor
argument'; nested exception is
Error creating bean with name 'config' defined in URL
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job
easier.
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-users mailing list
