[Geoserver-users] Geoserver on Ubuntu Tomcat 5.5
Problem solved!!!
The problem raises using default tomcat5 installation in an
Ubuntu/Debian system. That is because it is very restrictive with
default permissions, so you need to manually edit
/etc/tomcat5.5/policy.d/04webapps.policy file and add the following line
before closing bracket:
permission java.security.AllPermission;
Then all you have to do is restart tomcat and the geosever war will be
automatically deployed. Obviously it will be better to narrow
permissions, but this way I can make it work.
-----Mensaje original-----
De: Aitor Calero Garcia
Enviado el: lunes, 12 de febrero de 2007 11:35
Para: Alexander Petkov
CC: geoserver-users@lists.sourceforge.net
Asunto: Re: [Geoserver-users] Geoserver on Ubuntu Tomcat 5.5
> Do you have any data in there? Is the catalog.xml present?
What do you mean with "data in there"? I've just deploy the geoserver
war file in Tomcat, so I guess that it contains everything it needs.
Using Tomcat but need to do more? Need to support web services,
security?
Get stuff done quickly with pre-integrated technology to make your job
easier.
Download IBM WebSphere Application Server v.1.0.1 based on Apache
Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-users mailing list
Aitor Calero Garcia ha scritto:
Problem solved!!!
Cool, good for a user guide. I've installed Ubuntu yesterday on a virtual machine but still did not find the time to test geoserver
on it. I'll have a look, hopefully changes needed to make Geoserver run on restricted environments are not huge.
