[Geoserver-users] Geoserver online resource set as localhost - how can I change it?
Hi
I was having a look at my Geoserver WMS capabilities file and noticed that my GetCapabilities Online Resource is set as ‘localhost’ rather than my external URL address – where am I able to change this? Is this done in the Admin interface or would I need to configure a file elsewhere?
Thanks, Chris
You need to set the proxy base url on the global settings page - http://docs.geoserver.org/latest/en/user/configuration/globalsettings.html#proxy-base-url
Ian
On 18 August 2016 at 16:13, Chris Buckmaster <chris.buckmaster@…7473…> wrote:
Hi
Thanks, Chris
Geoserver-users mailing list
Geoserver-users@anonymised.com.382…sourceforge.net
Ian Turton
Chris and Ian,
Pelase note that the geowebcache url in the geoserver user interface is
bugged and still points to '127.0.0.1:8080' (localhost) even if you set
proxy base url correctly. The service works fine, but the page links to
the wrong address.
See
https://osgeo-org.atlassian.net/browse/GEOS-7653
Best,
Daniel
Em 18/08/2016 13:20, Ian Turton escreveu:
Ian
<chris.buckmaster@anonymised.com
<mailto:chris.buckmaster@anonymised.com>> wrote:
    Hi
    Thanks, Chris
    <mailto:Geoserver-users@lists.sourceforge.net>
    <https://lists.sourceforge.net/lists/listinfo/geoserver-users&gt;
Ian Turton
