I've been playing with geoserver and some test gps data, basically plotting them on google earth. I'm using geoserver 1.5.1, postgres 8.2.4 and postgis 1.2.1.
I've noticed that the first time I open google earth, it takes a very long time for the data to appear, but zooming in afterwards it was faster. But the speed would still vary. I just noticed, using ps -e, that I have about 45 postgres instances running. Is that normal (it's stopped spawning)?
Also, in google earth when I tried to see the 'states' that came with geoserver it shows a white overlay over the US instead of color coded. The same thing happens when I try to overlay polygons, for example, zip code outlines. If zoomed out it shows the outline correctly, but zoomed in everything becomes white. Does someone know what's the cause of this?
Doris
Hi Doris,
GeoServer has just recently drastically improved database connection management on the 1.6.x branch (trunk)... Unfortunately due the amount of effort involved it will not be back ported to the 1.5.x branch...
1.6 is currently in a beta state, with 1.6.0-beta2 just released. You can grab it here:
http://docs.codehaus.org/display/GEOS/Geoserver+1.6.0-beta2
-Justin
dlamoris@anonymised.com wrote:
Doris
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
Geoserver-users mailing list
!DSPAM:4007,469bb68275394901796417!
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Hi Doris, missed your second question
This is a bit strange... I have never seen this behavior before... what happens when you view the layer in the openlayers preview page... Do you notice the same problem at all?
Doris
Justin Deoliveira
The map preview page looks ok, it's just that in google earth it's white..
for the states it looks like a white rectangle over US no matter what zoom level it is. I also have another table with zip code polygons that renders correctly at high altitude, but zoomed in it becomes white. The placemark circles are there though.
Also, I tried to shutdown geoserver using the shutdown script, but it says:
The GEOSERVER_HOME environment variable is not defined correctly
This environment variable is needed to run this program
I'm sure I set the env var: export GEOSERVER_HOME=/usr/local/geoserver
and then $GEOSERVER_HOME/bin/shutdown.sh
Am I missing something...?
Doris
Quoting Justin Deoliveira <jdeolive@anonymised.com>:
Doris
Justin Deoliveira
What platform are you running on? Windows?
Doris
Doris
Justin Deoliveira
!DSPAM:4007,469bc5e7102861439371379!
Justin Deoliveira
Ubuntu 7
Doris
Doris
Justin Deoliveira
Justin Deoliveira
Ok... i am pretty sure this is a google earth linux problem... Chris is running ubuntu and having the same issue.. and i run gentoo and cant even add network links with google earth...
-Justin
Ubuntu 7
The map preview page looks ok, it's just that in google earth it's white...
Doris
Doris
Justin Deoliveira
Justin Deoliveira
!DSPAM:4007,469bc8b9108327180515871!
Justin Deoliveira
