I’m using Geoserver (2.3.0) + OpenLayers(2.12), but with no previous experience on GEO systems :(.
I need to locate in the map the item located in lat/long, or by the primary key. But I have found only the inverse situation, in other words, if the user clicks on item, it is possible to recover the lat/long.
Someone knows how to find this item?
's
Hi João,
I’m not really clear what you’re asking for. If you know the lat/lon you can either find what item is there (WMS - getFeatureInfo request), or pan the map there directly. Selecting by primary key would be a WFS query (getFeature I think). I’m not sure how these are packaged up in OpenLayers though.
Your question may be better suited to the OpenLayers mailing list however.
Jonathan
On 14 May 2013 14:01, João Carlos Zakrzevisk <jcarlaop@anonymised.com> wrote:
's
AlienVault Unified Security Management (USM) platform delivers complete
security visibility with the essential security capabilities. Easily and
efficiently configure, manage, and operate all of your security controls
from a single console and one unified framework. Download a free trial.
http://p.sf.net/sfu/alienvault_d2d
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
