Hallo, I`m quite new with geoserver and I have a brief question. What must I
do to have access to geoserver outside the localhost surrounding? When I
replace localhost with my IP adress nothing happens.
Thank you!
View this message in context: http://www.nabble.com/Geoserver-outside-localhost-tf3446625.html#a9611790
There's nothing you have to do in Geoserver itself. But I would check
your local firewall settings (if you have one). For example, I'm behind
a small router. To make geoserver visible on the internet I have to:
* open the 8080 port in the windows firewall
* configure the router to do source nat so that hitting the external
ip address on 8080 redirects the call to my pc
* use the external ip address in my calls to geoserver.
Hope this helps
