[Geoserver-users] Geoserver PostGIS WFS layer sometimes loses its prefix
I’m having a recurring problem where WFS responses on PostGIS layers in our Geoserver (2.2-RC1) will “lose” their prefix. In other words, the prefix comes back as null, causing a XML parsing error. What’s odd is that I can go into the Geoserver web admin interface, access the problem layer, click “Reload feature type”, and the layer will start working again. It will work OK for a few weeks and then do it again.
Does anyone know what could be wrong?
Thanks!
Matt
On Mon, Nov 26, 2012 at 3:51 PM, Matthew Foster - NOAA Federal <matthew.foster@anonymised.com> wrote:
I don’t remember this particular problem, but can you tell us which version of GeoServer you’re using?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
On Mon, Nov 26, 2012 at 11:12 AM, Andrea Aime
I'm having a recurring problem where WFS responses on PostGIS layers in
our Geoserver (2.2-RC1) will "lose" their prefix. In other words, the
prefix comes back as null, causing a XML parsing error. What's odd is that
click "Reload feature type", and the layer will start working again. It
I don't remember this particular problem, but can you tell us which
version of GeoServer you're using?
2.2-RC1
Back then I did not have a clue off the top of my head, but searching the archives leads to this:
http://www.mail-archive.com/geoserver-users@anonymised.comsourceforge.net/msg06924.html
So far, seems like a known problem with no immediate solution (aka, quite a bit of work
to fix it).
2.2-RC1
Thanks for the update Andrea.
I’m trying to understand the specifics of what is going on…global endpoint…virtual endpoint…it’s a tad over my head.
It sounds like there are potential workarounds, but I’m failing to grasp what they might be. Can you boil it down?
Matt
On Thu, Dec 13, 2012 at 9:59 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Mon, Nov 26, 2012 at 7:21 PM, Matthew Foster - NOAA Federal <matthew.foster@anonymised.com> wrote:
On Mon, Nov 26, 2012 at 11:12 AM, Andrea Aime <andrea.aime@anonymised.com07…> wrote:
http://www.mail-archive.com/geoserver-users@lists.sourceforge.net/msg06924.html
to fix it).
Ing. Andrea Aime
@geowolf
Technical Lead
2.2-RC1
Andrea,
I found one application using our server that was not having this problem, and it appears to be making its requests using WFS 1.0.0, which if I’m reading correctly, defaults to using GML 2. The applications that ARE having problems were specifying WFS 1.1.0, which I think defaults to GML 3. Is this a workaround? The email thread you linked to specifically mentioned GML 3 as being involved in the problem.
Matt
On Wed, Dec 19, 2012 at 8:52 PM, Matthew Foster - NOAA Federal <matthew.foster@anonymised.com> wrote:
Matt
to fix it).
Ing. Andrea Aime
@geowolf
Technical Lead
2.2-RC1
