On Wed, Dec 17, 2014 at 9:01 AM, Casper Børgesen (CABO) <CABO@anonymised.com..>
wrote:
Hi.
I have some problems with GeoServer (2.5.2) and PostGIS (2.1.1). When I
make a WFS request to a view on my database, I get a SELECT query like this:
SELECT "id",encode(ST_AsEWKB("geometry"),'base64') as "geometry" FROM
"public"."my_table" WHERE "geometry" && ST_GeomFromText('POLYGON
((891837.6082013508 6147533.812230958, 891837.6082013508 6148331.277858112,
893164.795314311 6148331.277858112, 893164.795314311 6147533.812230958,
891837.6082013508 6147533.812230958))', ST_SRID("geometry")) LIMIT 1000000
GeoServer falls back on this syntax when the srid of the geometry is not
known.
Can you verify the geoserver user can access the geometry_columns view?
Please, notice that GeoSolutions will be closed for seasonal holidays
from December the 24th to January the 6th
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
