Dear All
We get 404 - Not found errors when we try to enable print option from OpenLayers / Leaflet on CentOS through Post method. However, we are getting print through Get method.
Our environment is as follows:
GeoServer version is 2.8 on CentOS - Tomcat 7.0.67
PHP - 5.5.36; Apache with SSL
Config.yaml for security / hosts related section are:
With kind regards,
Mahalakshmi Narayanan
it looks like the following url is not reachable by the server itself: https://www.gisdomain.com:8080/geoserver/domain/wms?BBOX=8187100.555667659%2C655843.5302431142%2C9245433.863162776%2C1802371.2994081532&WIDTH=1667&HEIGHT=1806&format_options=dpi%3A100&map_resolution=100&FORMAT=image%2Fpng&REQUEST=GetMap&SRS=EPSG%3A3857&VERSION=1.1.1&STYLES=&SERVICE=WMS&DPI=100&transparent=true&LAYERS=domain%3Alayer1
Is this the same geoserver where the printing service is installed. Is it reachable from the GeoServer host?
Mauro
2016-12-15 12:00 GMT+01:00 Mahalakshmi Narayanan <mhln25@anonymised.com>:
Dear All
hosts:
Security:
- !basicAuth
matcher: !dnsMatch
host: www.gisdomain.com
port: 8080
username: xyz
password: abcd
preemptive: true
hosts:
Geoerver log gives the following
2016-11-25 17:47:17,669 WARN [yaml.CustomBeanWrapper] - Config: unknown field ‘Security’ with value ‘[org.mapfish.print.config.BasicAuthSecurity@anonymised.com]’
2016-11-25 17:47:17,674 WARN [yaml.CustomBeanWrapper] - ColumnsBlock: unknown field ‘height’ with value ‘150’
2016-11-25 17:47:17,681 WARN [yaml.CustomBeanWrapper] - ColumnsBlock: unknown field ‘height’ with value ‘100’
2016-11-25 17:47:17,702 WARN [servlet.PageNotFound] - No mapping found for HTTP request with URI [/geoserver/domain/wms] in DispatcherServlet with name ‘dispatcher’
2016-11-25 17:47:17,712 WARN [servlet.PageNotFound] - No mapping found for HTTP request with URI [/geoserver/domain/wms] in DispatcherServlet with name ‘dispatcher’
2016-11-25 17:47:17,714 ERROR [print.PDFUtils] - Server returned an error for https://www.gisdomain.com:8080/geoserver/domain/wms?BBOX=8187100.555667659%2C655843.5302431142%2C9245433.863162776%2C1802371.2994081532&WIDTH=1667&HEIGHT=1806&format_options=dpi%3A100&map_resolution=100&FORMAT=image%2Fpng&REQUEST=GetMap&SRS=EPSG%3A3857&VERSION=1.1.1&STYLES=&SERVICE=WMS&DPI=100&transparent=true&LAYERS=domain%3Alayer1: Error (status=404) while reading the image from https://www.gisdomain.com:8080/geoserver/domain/wms?BBOX=8187100.555667659%2C655843.5302431142%2C9245433.863162776%2C1802371.2994081532&WIDTH=1667&HEIGHT=1806&format_options=dpi%3A100&map_resolution=100&FORMAT=image%2Fpng&REQUEST=GetMap&SRS=EPSG%3A3857&VERSION=1.1.1&STYLES=&SERVICE=WMS&DPI=100&transparent=true&LAYERS=domain%3Alayer1: Not Found
2016-11-25 17:47:17,715 ERROR [print.PDFCustomBlocks] - Error while adding a PDF elementjava.io.IOException: Error (status=404) while reading the image from https://www.gisdomain.com:8080/geoserver/domain/wms?BBOX=8187100.555667659%2C655843.5302431142%2C9245433.863162776%2C1802371.2994081532&WIDTH=1667&HEIGHT=1806&format_options=dpi%3A100&map_resolution=100&FORMAT=image%2Fpng&REQUEST=GetMap&SRS=EPSG%3A3857&VERSION=1.1.1&STYLES=&SERVICE=WMS&DPI=100&transparent=true&LAYERS=domain%3Alayer1: Not Found
2016-11-25 17:47:17,835 WARN [yaml.CustomBeanWrapper] - Config: unknown field ‘Security’ with value ‘[org.mapfish.print.config.BasicAuthSecurity@anonymised.com]’
2016-11-25 17:47:17,841 WARN [yaml.CustomBeanWrapper] - ColumnsBlock: unknown field ‘height’ with value ‘150’
2016-11-25 17:47:17,852 WARN [yaml.CustomBeanWrapper] - ColumnsBlock: unknown field ‘height’ with value ‘100’
2016-11-25 17:47:30,536 WARN [servlet.PageNotFound] - No mapping found for HTTP request with URI [/geoserver/domain/wms] in DispatcherServlet with name ‘dispatcher’
Chennai and adjacent districts have been devasted due to Vardha cyclone… Any help to resolve the error would be highly appreciated, pls.
With kind regards,
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
Geoserver-users mailing list
Geoserver-users@anonymised.com.382…sourceforge.net
Hi
Thanks for the kind reply
When I do in terminal mode on the same server I get result as below which probably means it is accessible locally…
links https://www.gisdomain.com:8080/geoserver/domain/wms?BBOX=8187100.555667659%2C655843.5302431142%2C9245433.863162776%2C1802371.2994081532&WIDTH=1667&HEIGHT=1806&format_options=dpi%3A100&map_resolution=100&FORMAT=image%2Fpng&REQUEST=GetMap&SRS=EPSG%3A3857&VERSION=1.1.1&STYLES=&SERVICE=WMS&DPI=100&transparent=true&LAYERS=domain%3Alayer1
[1] 23594
[2] 23595
[3] 23596
[4] 23597
[5] 23598
[6] 23599
[7] 23600
[8] 23601
[9] 23602
[10] 23603
[11] 23604
[12] 23605
[13] 23606
[2] Done WIDTH=1667
[3] Done HEIGHT=1806
[4] Done format_options=dpi%3A100
[5] Done map_resolution=100
[6] Done FORMAT=image%2Fpng
[7] Done REQUEST=GetMap
[8] Done SRS=EPSG%3A3857
[9] Done VERSION=1.1.1
[10] Done STYLES=
[11] Done SERVICE=WMS
[12]- Done DPI=100
On Thu, Dec 15, 2016 at 4:55 PM, Mauro Bartolomeoli <maurobartolomeoli@anonymised.com> wrote:
Mauro
Dear All
hosts:
Security:
- !basicAuth
matcher: !dnsMatch
port: 8080
username: xyz
password: abcd
preemptive: true
hosts:
With kind regards,
Geoserver-users@anonymised.comrge.net
With kind regards,
Vilasini Narayanan
that response just means you need to escape the & in your url, try something like
curl https://www.gisdomain.com:8080/geoserver/domain/wms?BBOX=8187100.555667659%2C655843.5302431142%2C9245433.863162776%2C1802371.2994081532&WIDTH=1667&HEIGHT=1806&format_options=dpi%3A100&map_resolution=100&FORMAT=image%2Fpng&REQUEST=GetMap&SRS=EPSG%3A3857&VERSION=1.1.1&STYLES=&SERVICE=WMS&DPI=100&transparent=true&LAYERS=domain%3Alayer1
Ian
On 16 December 2016 at 06:38, Mahalakshmi Narayanan <mhln25@anonymised.com.84…> wrote:
Hi
[1] 23594
[2] 23595
[3] 23596
[4] 23597
[5] 23598
[6] 23599
[7] 23600
[8] 23601
[9] 23602
[10] 23603
[11] 23604
[12] 23605
[13] 23606
[2] Done WIDTH=1667
[10] Done STYLES=
[12]- Done DPI=100
Mauro
With kind regards,
Vilasini Narayanan
Dear All
hosts:
Security:
- !basicAuth
matcher: !dnsMatch
port: 8080
username: xyz
password: abcd
preemptive: true
hosts:
With kind regards,
Ian Turton
