we are using the printing module of Geoserver to print maps in our application. This is working fine.
After the security penetrationtests in our application an issue connected to this module has shown up. We have to solve this and we wonder if you have already a fix that we can use.
When you go to this URL http://host/geoserver/pdf/print.pdf?spec=1 an stacktrace message shows in the screen. Instead of this stacktrace an general error page should be shown. Do you know if it is possible to configure this module in Geoserver to achieve this?
/Monica
