[Geoserver-users] Geoserver printing module and Image in PDF
Hello people i am using geoserver 2.1.4 and i use the "geoserver-2.1-SNAPSHOT-printing-plugin.zip" module of geoserver to export the data and the images do not show in the pdf file, and in the log of geoserver i get this, i dont know ehat is this or what can i do to repair it, thanks to all
10.8.194.10 - - [19/jun/2013:09:58:34 +0000] "GET /geoserver/une/wms?BBOX=-79.5662%2C21.894983%2C-79.5218%2C21.914013&HEIGHT=208&WIDTH=486&TRANSPARENT=true&map_resolution=50&VERSION=1.1.1&FORMAT=image%2Fpng&TILED=true&SERVICE=WMS&format_options=dpi%3A50&LAYERS=une%3Asigfre_cub_Adm_Prov&REQUEST=GetMap&STYLES=&TILESORIGIN=-84.956%2C19.825&SRS=EPSG%3A4326 HTTP/1.1" 401 1495
10.8.194.10 - - [19/jun/2013:09:58:34 +0000] "GET /geoserver/une/wms?BBOX=-79.5662%2C21.894983%2C-79.5218%2C21.914013&HEIGHT=208&WIDTH=486&BGCOLOR=0x93B5DD&map_resolution=50&TILED=true&SERVICE=WMS&REQUEST=GetMap&STYLES=&TILESORIGIN=-84.956%2C19.825&TRANSPARENT=false&VERSION=1.1.1&FORMAT=image%2Fpng&format_options=dpi%3A50&LAYERS=une%3Asigfre_base&SRS=EPSG%3A4326 HTTP/1.1" 401 1495
10.8.194.10 - - [19/jun/2013:09:58:34 +0000] "GET /geoserver/une/wms?BBOX=-79.677216%2C21.810436%2C-79.4108%2C21.998562&HEIGHT=83&WIDTH=118&BGCOLOR=0x93B5DD&map_resolution=50&TILED=true&SERVICE=WMS&REQUEST=GetMap&STYLES=&TILESORIGIN=-84.956%2C19.825&TRANSPARENT=false&VERSION=1.1.1&FORMAT=image%2Fpng&format_options=dpi%3A50&LAYERS=une%3Asigfre_base&SRS=EPSG%3A4326 HTTP/1.1" 401 1495
10.8.194.10 - - [19/jun/2013:09:58:34 +0000] "GET /geoserver/une/wms?BBOX=-79.677216%2C21.810436%2C-79.4108%2C21.998562&HEIGHT=83&WIDTH=118&TRANSPARENT=true&map_resolution=50&VERSION=1.1.1&FORMAT=image%2Fpng&TILED=true&SERVICE=WMS&format_options=dpi%3A50&LAYERS=une%3Asigfre_cub_Adm_Prov&REQUEST=GetMap&STYLES=&TILESORIGIN=-84.956%2C19.825&SRS=EPSG%3A4326 HTTP/1.1" 401 1495
This message was sent using IMP, the Internet Messaging Program.
Este mensaje le ha llegado mediante el servicio de correo electronico que ofrece Infomed para respaldar el cumplimiento de las misiones del Sistema Nacional de Salud. La persona que envia este correo asume el compromiso de usar el servicio a tales fines y cumplir con las regulaciones establecidas
Infomed: http://www.sld.cu/
The part of the log you’re showing is simply the requests to the server. You should be enter them into your browser and see what the images that are being requested are - this will give an indication of what’s going on.
But you’ve not really given enough information to help discern what’s wrong. It could be any number of things. If you can turn logging up to GeoTools developer, that might add some extra stuff.
Jonathan
“geoserver-2.1-SNAPSHOT-printing-plugin.zip” module of geoserver to
10.8.194.10 - - [19/jun/2013:09:58:34 +0000] “GET
/geoserver/une/wms?BBOX=-79.5662%2C21.894983%2C-79.5218%2C21.914013&HEIGHT=208&WIDTH=486&TRANSPARENT=true&map_resolution=50&VERSION=1.1.1&FORMAT=image%2Fpng&TILED=true&SERVICE=WMS&format_options=dpi%3A50&LAYERS=une%3Asigfre_cub_Adm_Prov&REQUEST=GetMap&STYLES=&TILESORIGIN=-84.956%2C19.825&SRS=EPSG%3A4326 HTTP/1.1” 401
1495
/geoserver/une/wms?BBOX=-79.5662%2C21.894983%2C-79.5218%2C21.914013&HEIGHT=208&WIDTH=486&BGCOLOR=0x93B5DD&map_resolution=50&TILED=true&SERVICE=WMS&REQUEST=GetMap&STYLES=&TILESORIGIN=-84.956%2C19.825&TRANSPARENT=false&VERSION=1.1.1&FORMAT=image%2Fpng&format_options=dpi%3A50&LAYERS=une%3Asigfre_base&SRS=EPSG%3A4326 HTTP/1.1” 401
1495
/geoserver/une/wms?BBOX=-79.677216%2C21.810436%2C-79.4108%2C21.998562&HEIGHT=83&WIDTH=118&BGCOLOR=0x93B5DD&map_resolution=50&TILED=true&SERVICE=WMS&REQUEST=GetMap&STYLES=&TILESORIGIN=-84.956%2C19.825&TRANSPARENT=false&VERSION=1.1.1&FORMAT=image%2Fpng&format_options=dpi%3A50&LAYERS=une%3Asigfre_base&SRS=EPSG%3A4326 HTTP/1.1” 401
1495
/geoserver/une/wms?BBOX=-79.677216%2C21.810436%2C-79.4108%2C21.998562&HEIGHT=83&WIDTH=118&TRANSPARENT=true&map_resolution=50&VERSION=1.1.1&FORMAT=image%2Fpng&TILED=true&SERVICE=WMS&format_options=dpi%3A50&LAYERS=une%3Asigfre_cub_Adm_Prov&REQUEST=GetMap&STYLES=&TILESORIGIN=-84.956%2C19.825&SRS=EPSG%3A4326 HTTP/1.1” 401
1495
This SF.net email is sponsored by Windows:
Build for Windows Store.
http://p.sf.net/sfu/windows-dev2dev
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On Fri, Jun 21, 2013 at 12:03 PM, Jonathan Moules <
jonathanmoules@anonymised.com> wrote:
The part of the log you're showing is simply the requests to the server.
being requested are - this will give an indication of what's going on.
But you've not really given enough information to help discern what's
I believe he's looking into the Jetty request log, whilst the interesting
information might be in $GEOSERVER_DATA_DIR/logs/geoserver.log :-p
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Good catch, I should have spotted that!
I believe he’s looking into the Jetty request log, whilst the interesting information might be in $GEOSERVER_DATA_DIR/logs/geoserver.log :-p
Ing. Andrea Aime
@geowolf
Technical Lead
It seems from the log that he get’s a “401 - Unauthorized” http status code. That sounds like Geoserver is requesting the url in a different context than the original requests.
I don’t know the module, but it would be interesting to find out how it works.
Best regards
Roar Brænden
2013/6/21 Jonathan Moules <jonathanmoules@anonymised.com>
On 21 June 2013 11:14, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Fri, Jun 21, 2013 at 12:03 PM, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
