The layers that I can’t get to print are layers that I have added to my map using OpenLayers 2.12. The vector layer has objects that were read from a WMS layer using WFS and reading the protocol using a filter. The REST API layers that I can’t get to print are from other servers, and the layers display fine in my map and have been put into the config.yaml file as accepted hosts. Does any of this affect whether or not the layer will print?
The error that I get in both situations is below:
2013-10-29 15:22:19,475 DEBUG [org.geotools.image] - Encoded input image for png writer
2013-10-29 15:22:19,475 DEBUG [org.geotools.image] - Getting a writer
2013-10-29 15:22:19,475 DEBUG [org.geotools.image] - Unable to use Native ImageIO PNG writer.
2013-10-29 15:22:19,476 DEBUG [org.geotools.image] - Using ImageIO Writer with SPI: com.sun.imageio.plugins.png.PNGImageWriterSpi
2013-10-29 15:22:19,476 DEBUG [org.geotools.image] - Setting write parameters for this writer
2013-10-29 15:22:19,476 DEBUG [org.geotools.image] - Writer is NOT native
2013-10-29 15:22:19,476 DEBUG [org.geotools.image] - About to write png image
I tried running the little program below, but could not get it to work. I am not enough of a programmer to know why. I am not sure where to find the imageio extension that I need.
Jerome
From: Jerome A. Wendell [mailto:jawendell@anonymised.com]
Sent: Tuesday, October 29, 2013 2:22 PM
To: ‘Jesse Eichar’
Cc: ‘Mauro Bartolomeoli’; ‘GeoServer Mailing List List’
Subject: RE: [Geoserver-users] GeoServer Printing Module
Jesse,
Thanks for your reply. I apologize for the continued questions, but I am still trying to find out what is causing my problem. The following files are in the /lib/ext directory:
Are these the correct files, or should there be others?
Jerome
From: Jesse Eichar [mailto:jesse.eichar@anonymised.com…]
Sent: Tuesday, October 29, 2013 2:12 PM
To: jawendell@anonymised.com
Cc: Mauro Bartolomeoli; GeoServer Mailing List List
Subject: Re: [Geoserver-users] GeoServer Printing Module
Those are not actually the jars you need. Those are to allow some geotools plugins to use Image-io. There are 2 ways to have image io installed.
Software emulation. In this case you need the imageio jars in your WEB-INF/lib folder. I can’t remember exactly which at the moment something like jai_imagio.jar or something
Java extension is installed. This you can see by looking in /lib/ext
You can write a little program to see if you have it installed. Something like:
for (String name : javax.imageio.ImageIO.getReaderFormatNames()) {
System.out.println(name);
Jesse
On Tue, Oct 29, 2013 at 5:19 PM, Jerome A. Wendell <jawendell@anonymised.com> wrote:
Jesse,
It appears the imageio extension is installed based on the following files being in the WEB-INF/lib directory:
Are there other files that should be installed?
Jerome
Sent: Tuesday, October 29, 2013 9:55 AM
To: ‘Jesse Eichar’
Jesse,
Thanks for your reply. Yes, the OSM and WMS layers are printing fine. I have some base layers from servers using the REST API that give the same error.
I will check on the imageio extension.
Jerome
From: Jesse Eichar [mailto:jesse.eichar@anonymised.com.]
Sent: Tuesday, October 29, 2013 9:49 AM
To: jawendell
Cc: Jonathan Moules; Mauro Bartolomeoli; GeoServer Mailing List List
For PDF you don’t need imagemagick.
I looked to quickly at the logs you gave. Those aren’t issues with vector or png output. It looks like it is the internals of JAVA.IO
I assume there are layers other than just the vector layer? Are they printing correctly?
Maybe try getting the vectors as svg?
Also make sure that you have java’s imageio extension installed.
Jesse
On Tue, Oct 29, 2013 at 2:13 PM, Jerome A. Wendell <jawendell@anonymised.com> wrote:
Jesse,
Thanks for your reply. Actually I am trying to print to a PDF file. Does that still require image magick?
Jerome
From: Jesse Eichar [mailto:jesse.eichar@anonymised.com]
Sent: Tuesday, October 29, 2013 9:09 AM
If you are trying to write to a PNG you need to install image magick and use the print war that is configured to use image magick:
http://www.mapfish.org/doc/print/installation.html#with-image-output-line
Jesse
On Tue, Oct 29, 2013 at 2:04 PM, Jerome A. Wendell <jawendell@anonymised.com> wrote:
Jonathan,
Thanks for the suggestion. The following was written to the logs when I tried to print with the vector layer:
2013-10-29 08:57:13,425 DEBUG [org.geotools.image] - Encoded input image for png writer
2013-10-29 08:57:13,425 DEBUG [org.geotools.image] - Getting a writer
2013-10-29 08:57:13,425 DEBUG [org.geotools.image] - Unable to use Native ImageIO PNG writer.
2013-10-29 08:57:13,425 DEBUG [org.geotools.image] - Using ImageIO Writer with SPI: com.sun.imageio.plugins.png.PNGImageWriterSpi
2013-10-29 08:57:13,426 DEBUG [org.geotools.image] - Setting write parameters for this writer
2013-10-29 08:57:13,426 DEBUG [org.geotools.image] - Writer is NOT native
2013-10-29 08:57:13,426 DEBUG [org.geotools.image] - About to write png image
It appears the required writer is not present. Is this something that I can download from another web site?
Jerome Wendell
From: Jonathan Moules [mailto:jonathanmoules@anonymised.com]
Sent: Tuesday, October 29, 2013 8:44 AM
HI Jerome,
I’m using a standalone MapFish Print deployment, but the vector should work just fine if the WMS/OSM is. Have a look in your logs; you may want to turn them up to Geotools_developer level.
The logs should hopefully indicate what is happening.
Jonathan
On 28 October 2013 12:38, Jerome A. Wendell <jawendell@anonymised.com> wrote:
Mauro,
Thank you very much for your reply. I found the two files in the MapFish repository, and have placed them in the WEB-INF/lib directory. The printing plugin seems to be working fine now for OSM and WMS layers, but when I try to print vector layers overlaid on the map, the process immediately aborts. Do I need to do something different in order to be able to print vector layers?
Thanks for your help,
Jerome Wendell
From: maurobartolomeoli@anonymised.com [mailto:maurobartolomeoli@anonymised.com] On Behalf Of Mauro Bartolomeoli
Sent: Monday, October 28, 2013 4:21 AM
Cc: GeoServer Mailing List List
Hi Jerome, from the exception you get, it seems some java class is missing from your deploy. If you are using one of the latest GeoServer versions, 2.4.0 or 2.4.1, your problem could be that a couple of jars are missing from Geoserver WEB-INF/lib, because xerces dependency has been removed from Geoserver but the printing plugin still depends on it.
The two jars are xml-api-xerces-2.7.1.jar and xercesImpl-2.7.1.jar.
You can try to get them from an older geoserver version or I can send you them privately.
Please, let me know if this could your issue.
Mauro Bartolomeoli
2013/10/26 Jerome A. Wendell <jawendell@anonymised.com>
Mauro,
Thanks for your reply, I appreciate it. I followed those instructions to install the plugin. The config.yaml file was created and I can retrieve a list of printing parameters from http://localhost:8080/geoserver/pdf/info.json. When I open the sample page in those instructions, I can read the information at the top of the page and there is a link to the source code, but there is no map. GeoServer is running at http://localhost:8080/geoserver/. I failed to mention in my original post that I have also installed GeoExt (I followed the instruction on the GeoExt web site at http://geoext.org/tutorials/quickstart.html.) and Ext JS (I also made the changes recommeneded for IIS on the http://www.sencha.com web site at this link). So my current configuration on a Windows server is:
OpenLayers 2.12, GeoServer 2.4.0, GeoExt 1.1 and Ext JS 3.4.1
By reading on the GeoExt web site I concluded that I need to install GeoExt and Ext JS. I am currently loading the printCapabilities using the following script tag:
I am using the following code to print the map:
// The printProvider that connects us to the print service
printProvider = new GeoExt.data.PrintProvider({
method: “GET”, // “POST” recommended for production use
capabilities: printCapabilities, // from the info.json script in the html
customParams: {
mapTitle: “Printing Demo”,
comment: “This is a map printed from GeoExt.”
var laycenter = map.getCenter();
var layzoom = map.getZoom();
printPage = new GeoExt.data.PrintPage({
printProvider: printProvider
mapPanel = new GeoExt.MapPanel({
region: “center”,
map: map,
center: laycenter,
zoom: layzoom
// A MapPanel with a “Print…” button
new Ext.Panel({
renderTo: “Map”,
layout: “border”,
width: 1060,
height: 785,
items: mapPanel,
bbar: [“->”, {
text: “Print”,
handler: function(){
printPage.fit(mapPanel, true);
printProvider.print(mapPanel, printPage);
The map is an OpenLayers map that has several layers, and I have tried printing it with just an OSM layer, and I get the following error:
2013-10-26 11:16:37,428 ERROR [servlet.BaseMapServlet] - Error while generating PDF
java.lang.NoClassDefFoundError: Could not initialize class org.mapfish.print.map.renderers.TileRenderer
at org.mapfish.print.map.readers.HTTPMapReader.render(HTTPMapReader.java:81)
at org.mapfish.print.map.MapChunkDrawer.renderImpl(MapChunkDrawer.java:162)
at org.mapfish.print.ChunkDrawer.render(ChunkDrawer.java:55)
at org.mapfish.print.ChunkDrawer.tableLayout(ChunkDrawer.java:49)
at com.lowagie.text.pdf.PdfPTable.writeSelectedRows(Unknown Source)
at com.lowagie.text.pdf.ColumnText.goComposite(Unknown Source)
at com.lowagie.text.pdf.ColumnText.go(Unknown Source)
at com.lowagie.text.pdf.PdfPRow.writeCells(Unknown Source)
at com.lowagie.text.pdf.PdfDocument.addPTable(Unknown Source)
at com.lowagie.text.pdf.PdfDocument.add(Unknown Source)
at com.lowagie.text.Document.add(Unknown Source)
at org.mapfish.print.config.layout.Page$1.add(Page.java:67)
at org.mapfish.print.config.layout.MapBlock.render(MapBlock.java:66)
at org.mapfish.print.config.layout.Page.render(Page.java:65)
at org.mapfish.print.config.layout.MainPage.render(MainPage.java:62)
at org.mapfish.print.config.layout.Layout.render(Layout.java:59)
at org.mapfish.print.MapPrinter.print(MapPrinter.java:144)
at org.mapfish.print.servlet.MapPrinterServlet.doCreatePDFFile(MapPrinterServlet.java:275)
at org.mapfish.print.servlet.MapPrinterServlet.createAndGetPDF(MapPrinterServlet.java:130)
at org.mapfish.print.servlet.MapPrinterServlet.doGet(MapPrinterServlet.java:68)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:159)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:43)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:205)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
When I try to print the map with a vector layer overlaid on the OSM layer, the GET print.pdf?spec . . . is immediately aborted. I have also tried it with POST and get the same result. When I try printing the map with a WMS layer overlaid on the OSM map, I get the same java.lang.NoClassDefFoundError as listed above.
I have edited the config.yaml file to include the required hosts to print the map by adding to the hosts section:
host: www.mydomain.com
host: a.tile.openstreetmap.org
It seems like something is missing in my configuration, but I have followed the instructions on each web site. I have been researching the error on the web, but have not found anything that resolved the problem.
If you have any questions or need more information, please let me know. I apologize for the long post, but I wanted to supply as many details as I could.
I appreciate any help or suggestions that you care to give.
Jerome Wendell
From: Mauro Bartolomeoli [mailto:maurobartolomeoli@anonymised.com]
Sent: Saturday, October 26, 2013 3:48 AM
Hi Jerome,
have you followed the instructions you can find here (http://docs.geoserver.org/stable/en/user/community/printing/) to install the plugin?
What kind of errors are you getting, in detail?
Mauro Bartolomeoli
2013/10/25 Jerome A. Wendell <jawendell@anonymised.com>
This may seem like a silly question, but once I have installed the GeoServer printing module and have confirmed that it is installed correctly, should everything be ready for me to print using the documentation and examples at the following link:
http://geoext.org/search.html?q=print
I have tried some of the examples and continue to get various errors. Just trying to make sure that I am not missing something.
Jerome Wendell
October Webinars: Code for Performance
Free Intel webinars can help you accelerate application performance.
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most from
the latest Intel processors and coprocessors. See abstracts and register >
http://pubads.g.doubleclick.net/gampad/clk?id=60135991&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via Poggio alle Viti 1187
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Android is increasing in popularity, but the open development platform that
developers love is also attractive to malware creators. Download this white
paper to learn more about secure code signing practices that can help keep
Android apps secure.
http://pubads.g.doubleclick.net/gampad/clk?id=65839951&iu=/4140/ostg.clktrk
