Hi All,
I tried to use GeoServer WMS to render OSM data onto my map client and what
I saw was not what I expected. I uploaded the three screenshots of the map
so that you can see what I saw. I also uploaded the two sld files that I
used for the polygon, line, and roads layers. I left the remaining
configurations as default. Below is what I saw:
1. When the map client first came up, California OSM layer did not show up.
2. I had to zoom in quite bits before I saw some part of California show up
on the map. (screenshot1.jpg)
3. I had to zoom some more before I saw screenshot2.jpg and screenshot3.jpg.
Note: my OSM data is California, USA.
My question is why only some parts of California shows up and not all of
them. That is not what I saw from OSM map site. Is there any parameter
that I can tweak to fix this problem. Below is one of the GetMap request
from my client in the tomcat log. Any help on this is greatly appreciated.
Please let me know if you need anymore information.
Request: getMap
SRS = CRS:84
FeatureVersion = null
Width = 512
Height = 512
Styles = [StyleImpl[ name=osm_polygon], StyleImpl[ name=osm_line],
StyleImpl[ name=osm_line]]
Palette = null
Tiled = false
Layers = [org.geoserver.wms.MapLayerInfo@anonymised.com,
org.geoserver.wms.MapLayerInfo@anonymised.com]
MaxFeatures = null
Crs = GEOGCS["WGS84",
DATUM["WGS84",
SPHEROID["WGS84", 6378137.0, 298.257223563]],
PRIMEM["Greenwich", 0.0],
UNIT["degree", 0.017453292519943295],
AXIS["Geodetic longitude", EAST],
AXIS["Geodetic latitude", NORTH],
AUTHORITY["Web Map Service CRS","84"]]
Bbox = ReferencedEnvelope[-126.0 : -117.0, 36.0 : 45.0]
RemoteOwsType = null
RemoteOwsURL = null
Env = {}
FormatOptions = {}
Angle = 0.0
CQLFilter = null
Elevation =
FeatureId = null
StartIndex = null
ViewParams = null
BgColor = java.awt.Color[r=255,g=255,b=255]
Transparent = true
SldBody = null
ValidateSchema = false
Sld = null
SldVersion = null
TilesOrigin = null
Exceptions = SE_XML
Format = image/png
Buffer = 0
Filter = null
Filters = null
Time =
Get = true
RawKvp = {CRS=CRS:84, TRANSPARENT=TRUE, BBOX=-126.0,36.0,-117.0,45.0,
VERSION=1.3, FORMAT=image/png, SERVICE=WMS, HEIGHT=512, REQUEST=GetMap,
LAYERS=California, STYLES=, WIDTH=512}
BaseUrl = http://172.16.203.150:8080/geoserver/
RequestCharset = UTF-8
Version = 1.3
Request = GetMap
osm_line.sld
<http://osgeo-org.1560.x6.nabble.com/file/n5104772/osm_line.sld>
osm_polygon.sld
<http://osgeo-org.1560.x6.nabble.com/file/n5104772/osm_polygon.sld>
<http://osgeo-org.1560.x6.nabble.com/file/n5104772/screenshot1.jpg>
<http://osgeo-org.1560.x6.nabble.com/file/n5104772/screenshot2.jpg>
<http://osgeo-org.1560.x6.nabble.com/file/n5104772/screenshot3.jpg>
Tam
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-renders-OSM-data-tp5104772.html
