I am trying to reproject GeoTiff layers in geoserver from their default of EPSG:4326 to EPSG:3574.
When the layer is a feature (PostGIS or Shapefile), it renders perfectly.
When the layer is a coverage, it does not appear to render at all, but I can execute GetFeatureInfo requests and retrieve data for the selected location.
So far I am assuming operator error, but I can not figure out what.
I can reproduce my problem using the standalone geoserver.war using the nurc:Img_Sample.
For example, after retrieving Img_Sample using the default bbox & SRS, if I change the request to:
http://localhost:8080/geoserver/nurc/wms?service=WMS&version=1.1.0&request=GetMap&layers=nurc:Img_Sample&styles=&bbox=166021.44,0.00,534994.66,9329005.18&width=768&height=372&srs=EPSG:32615&format=image/png
I no longer see the image, but I can request RGB via GetFeatureInfo.
There is one raster in the default data set in a non-EPSG:4326 projection. The native projection for sfdem is EPSG:26713. This layer renders in both EPSG:26713 and EPSG:4326. Is it possible that geoserver will only reproject when the native SRS is a 'PROJCS'? EPSG:4326 is a 'GEOGCS' - might this make a difference?
If I use gdalwarp to transform my geoTiff to EPSG:3832, PDC Mercator, then I can request it as both 3832 and 4326.
I also posted my problem here:
http://gis.stackexchange.com/questions/155464/geoserver-renders-reprojected-raster-only-as-transparent-images
Half-baked ideas welcome!
Dave
CONFIDENTIALITY WARNING: This e-mail may contain proprietary, privileged, or sensitive information of Applied Physical Sciences Corp. Any unauthorized use or disclosure of this communication is prohibited. Contractual restrictions may also apply to third parties. If you believe that you have received this email in error, please notify the sender immediately and delete it from your system.
