[Geoserver-users] Geoserver reports "org.h2.jdbc.JdbcSQLException: Database is already closed"
We are using:
GeoServer-2.2.5
Java 1.8
We suddenly could not connect to the Geoserver REST API from our Java code
anymore, Spring gave us this error:
org.springframework.web.client.ResourceAccessException: I/O error:
Connection refused; nested exception is java.net.ConnectException:
Connection refused
And then looking at the Geoserver log, we saw:
2015-10-01 15:36:57,598 ERROR [jdbc.JDBCMBWrapper] - Couldn't obtain JDBC
Connection to perform database shut down
org.h2.jdbc.JdbcSQLException: Database is already closed (to disable
automatic closing at VM shutdown, add ";DB_CLOSE_ON_EXIT=FALSE" to the db
URL) [90121-119]
                at org.h2.message.Message.getSQLException(Message.java:106)
                at org.h2.message.Message.getSQLException(Message.java:117)
                at org.h2.message.Message.getSQLException(Message.java:76)
                at org.h2.message.Message.getSQLException(Message.java:152)
                at
org.h2.jdbc.JdbcConnection.checkClosed(JdbcConnection.java:1328)
                at
org.h2.jdbcx.JdbcXAConnection$PooledJdbcConnection.checkClosed(JdbcXAConnection.java:505)
                at
org.h2.jdbc.JdbcConnection.checkClosed(JdbcConnection.java:1303)
                at
org.h2.jdbc.JdbcConnection.setAutoCommit(JdbcConnection.java:354)
                at
org.geowebcache.storage.metastore.jdbc.JDBCMBWrapper.getConnection(JDBCMBWrapper.java:183)
                at
org.geowebcache.storage.metastore.jdbc.JDBCMBWrapper.destroy(JDBCMBWrapper.java:618)
                at
org.geowebcache.storage.metastore.jdbc.JDBCMetaBackend.destroy(JDBCMetaBackend.java:265)
                at sun.reflect.NativeMethodAccessorImpl.invoke0(Native
Method)
                at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
                at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
                at java.lang.reflect.Method.invoke(Method.java:606)
                at
org.springframework.beans.factory.support.DisposableBeanAdapter.invokeCustomDestroyMethod(DisposableBeanAdapter.java:208)
                at
org.springframework.beans.factory.support.DisposableBeanAdapter.destroy(DisposableBeanAdapter.java:165)
                at
org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.destroyBean(DefaultSingletonBeanRegistry.java:456)
                at
org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.destroySingleton(DefaultSingletonBeanRegistry.java:434)
                at
org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.destroySingletons(DefaultSingletonBeanRegistry.java:407)
                at
org.springframework.context.support.AbstractApplicationContext.destroyBeans(AbstractApplicationContext.java:854)
                at
org.springframework.context.support.AbstractApplicationContext.doClose(AbstractApplicationContext.java:832)
                at
org.springframework.context.support.AbstractApplicationContext.close(AbstractApplicationContext.java:795)
                at
org.springframework.web.context.ContextLoader.closeWebApplicationContext(ContextLoader.java:361)
                at
org.springframework.web.context.ContextLoaderListener.contextDestroyed(ContextLoaderListener.java:70)
                at
org.mortbay.jetty.handler.ContextHandler.doStop(ContextHandler.java:574)
                at
org.mortbay.jetty.webapp.WebAppContext.doStop(WebAppContext.java:485)
                at
org.mortbay.component.AbstractLifeCycle.stop(AbstractLifeCycle.java:64)
                at
org.mortbay.jetty.handler.HandlerCollection.doStop(HandlerCollection.java:169)
                at
                at
                at
                at
org.mortbay.jetty.handler.HandlerWrapper.doStop(HandlerWrapper.java:142)
                at org.mortbay.jetty.Server.doStop(Server.java:281)
                at
                at
org.mortbay.jetty.Server$ShutdownHookThread.run(Server.java:559)
I tried to search online but wasn't able to find info on what might have
caused the database issue. I'm wondering if you have any hints for me?
Thanks
eting
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-reports-org-h2-jdbc-JdbcSQLException-Database-is-already-closed-tp5227479.html
it’s really hard to help since your GeoServer version is quite old, it’s a 2.2.x, the currently
supported versions are 2.7.x and 2.8.x (and a lot has changed in the codebase in the meantime).
I also think the two errors you’re seeing are not directly related, the first seems a runtime
error, the second is a shutdown error instead.
I know at some point the EPSG database happened to close itself due to lack of usage
(when all the recently used CRSs were cached) and a request with a new CRS ended
up triggering an error, but I don’t exactly remember when that was fixed.
But, as said, the two errors seem to be unrelated.
You might want to search in the ml archives from two years ago, there might be some clue.
On Fri, Oct 2, 2015 at 3:39 AM, eting123 <eting@anonymised.com> wrote:
We are using:
GeoServer-2.2.5
Java 1.8
Connection refused
2015-10-01 15:36:57,598 ERROR [jdbc.JDBCMBWrapper] - Couldn’t obtain JDBC
automatic closing at VM shutdown, add “;DB_CLOSE_ON_EXIT=FALSE” to the db
URL) [90121-119]
at
at
at
at
at
at
at
Method)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
I tried to search online but wasn’t able to find info on what might have
caused the database issue. I’m wondering if you have any hints for me?
Thanks
eting
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
