I am using geoserver 2.6.1 and spent some time on getting used with the REST API. I basically followed REST examples for cURL from here:
http://docs.geoserver.org/stable/en/user/rest/examples/curl.html
I managed to define and configure a new image mosaic via
curl -u admin:geoserver -XPUT -H "Content-type:application/zip" --data-binary @testmosaic.zip http://<IPaddress>/geoserver/rest/workspaces/myworkspace/coveragestores/testmosaic/file.imagemosaic
The difference to the curl example from the geoserver docs is just the location of the geoserver. I run the curl command from my local machine. The geoserver is running on another machine within the local network. But everything worked fine.
But it another story when I want to harvest another file to an existing imagemosaic. The geoserver docs give the following command, which I adapted for my configuration:
curl -v -u admin:geoserver -XPOST -H "Content-type: text/plain" -d file:///path/to/the/file/newfile.tif http://<IPaddress>/geoserver/rest/workspaces/myworkspace/coveragestores/testmosaic/external.imagemosaic
Here I get an error that the file 'file:///path/to/the/file/newfile.tif ’ was not found, when I run the command from my local machine with a file path on my local machine.
If I transfer the image file to the geoserver machine and run the command directly on the geoserver machine the file is harvested to the imagemosaic without problems.
My question: is there a possibility to harvest new files from my local machine to an existing imagemosaic when the geoserver is not running on the local machine but on another machine within the local network? Or is that procedure not intended?
Kind regards,
Sabine Ohlendorf
Hi Sabine,
sorry for the delay. If you want to harvest a local file from to a GeoServer located into another machine you can use two methods:
- Mount a storage pointing to your local machine on the GeoServer machine and harvest the file using the “external.imagemosaic” extension.
- Zip the file to harvest and then harvest it using the “file.imagemosaic” extension. You have to use the zip file because otherwise you can’t mantain the filename and this could be bad in cas of ImageMosaic with external dimensions. Note that you have to set the Content-type to “application/zip”
Using the “external.imagemosaic” extension requires that the file is reachable from the GeoServer machine; using “file.imagemosaic” instead allows to move your files into the Store directory.
Hoping it could help.
Nicola Lagomarsini.
2015-01-16 15:07 GMT+01:00 Sabine Ohlendorf <sabine.ohlendorf@anonymised.com>:
Kind regards,
Sabine Ohlendorf
New Year. New Location. New Benefits. New Data Center in Ashburn, VA.
GigeNET is offering a free month of service with a new server in Ashburn.
Choose from 2 high performing configs, both with 100TB of bandwidth.
Higher redundancy.Lower latency.Increased capacity.Completely compliant.
http://p.sf.net/sfu/gigenet
Geoserver-users mailing list
Ing. Nicola Lagomarsini
Junior Software Engineer
Via Poggio alle Viti 1187
Hi Nicola,
thank you very much for your response. I managed to harvest a file as a zipfile by using the "file.imagemosaic" extension. Great!
Just a comment for all who also want to harvest files to a GeoServer located on another machine: It is necessary to use the @-sign within the curl command.
curl -v -u admin:geoserver -XPOST -H "Content-type:application/zip" --data-binary @///path/to/the/zipfile/update.zip http://<IPaddress>/geoserver/rest/workspaces/myworkspace/coveragestores/testmosaic/file.imagemosaic
Otherwise the zipfile is not fully uploaded which results in an error.
Sabine
Gesendet: Mittwoch, 21. Januar 2015 um 14:00 Uhr
Von: "Nicola Lagomarsini" <nicola.lagomarsini@anonymised.com>
An: "Sabine Ohlendorf" <sabine.ohlendorf@anonymised.com>
Cc: "geoserver-users@lists.sourceforge.net" <geoserver-users@anonymised.comrceforge.net>
Betreff: Re: [Geoserver-users] geoserver REST API imagemosaic
Hi Sabine,
Mount a storage pointing to your local machine on the GeoServer machine and harvest the file using the "external.imagemosaic" extension.
Zip the file to harvest and then harvest it using the "file.imagemosaic" extension. You have to use the zip file because otherwise you can't mantain the filename and this could be bad in cas of ImageMosaic with external dimensions. Note that you have to set the Content-type to "application/zip"
Using the "external.imagemosaic" extension requires that the file is reachable from the GeoServer machine; using "file.imagemosaic" instead allows to move your files into the Store directory.
Nicola Lagomarsini.
