On Wed, Jan 6, 2016 at 10:41 PM, Schabowsky, Amanda <aschabow@anonymised.com>
wrote:
Has anyone seen this before or know why GeoServer is reporting that a
coverage store does not exist when it does?
Never heard of it... in my experience when it says it's not there, it's
actually not there.
Is the creation of the store returning a HTTP 200? What exact response do
you get on
creation, and when it claims the store not to be there?
Also, when that happens, do you see it on the UI? Does it eventually show
up in the UI or REST?
Finally, how are you managing the clustering, any plugin, is the data dir
shared or replicated,
what OS are you using, and if any, what shared filesystem?
*Geosolutions' Winter Holidays from 24/12 to 6/1*
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
