[Geoserver-users] geoserver returning 8 bit image
when I am making a request to geoserver from osgearth,in return it's giving
me tiles in 8 bit rgb image....originally when I stored the image ,it was a
16 bit .tif image in a single band.Now I want that Geoserver must return me
a 16 bit single(or even 16 bit rgb) band image when i make it request....How
can i coerce it doing so?
View this message in context: http://www.nabble.com/geoserver-returning-8-bit-image-tp24310430p24310430.html
I think you need first to exactly understand what you are doing.
WMS returns a rendered version of your data, that's why you are
getting a 8 bit image.
If you need to get access to the raw data you need to pass via WCS.
To answer your question, you can't get a 16 bits image out of WMS.
Simone.
Ing. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
On Thu, Jul 2, 2009 at 6:59 PM, shashank520<bajpai.shashank20@anonymised.com> wrote:
Geoserver-users mailing list
hi 520,
please let me know how to display 16 bit image in geoserver because when i try to upload it is giving only black output in geoserver.
thanks
pinki
On Thu, Jul 2, 2009 at 10:29 PM, shashank520 <bajpai.shashank20@anonymised.com> wrote:
when I am making a request to geoserver from osgearth,in return it’s giving
me tiles in 8 bit rgb image…originally when I stored the image ,it was a
a 16 bit single(or even 16 bit rgb) band image when i make it request…How
Pinki,
just a guess (unless you give meaningful information it is quite
impossible to help you out) you are tryin to expose 16 bits remote
sensing data whose dynamic is compressed towards 0 and you are getting
a black map (which is correct btw) out of it.
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
On Fri, Jul 3, 2009 at 3:27 PM, Pinki Gajjar<pinki.gajjar@anonymised.com> wrote:
hi 520,
thanks
pinki
wrote:
giving
a
me
request....How
Hi Simone,
Your guess is correct my image gets compressed do you know what can be the solution?
i told to sir and he is telling me that you are correct but i want to display that image in geoserver do you know any solution.
thanks
pinki
On Fri, Jul 3, 2009 at 7:04 PM, Simone Giannecchini <simboss1@anonymised.com84…> wrote:
Pinki,
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
hi 520,
thanks
pinki
On Thu, Jul 2, 2009 at 10:29 PM, shashank520 <bajpai.shashank20@anonymised.com84…>
wrote:
giving
a
me
request…How
Geoserver-users@anonymised.comnet
Try to use the ContrastEnhancement element of the raster symbolizer.
http://geoserver.org/display/GEOSDOC/RasterSymbolizer
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
On Fri, Jul 3, 2009 at 4:08 PM, Pinki Gajjar<pinki.gajjar@anonymised.com> wrote:
Hi Simone,
solution?
thanks
pinki
On Fri, Jul 3, 2009 at 7:04 PM, Simone Giannecchini <simboss1@anonymised.com>
wrote:
Pinki,
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
wrote:
> hi 520,
> i
> thanks
> pinki
> wrote:
>> Hi,
>> giving
>> was
>> a
>> return
>> me
>> request....How
>> _______________________________________________
>> Geoserver-users@lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geoserver-users
