[Geoserver-users] Geoserver´s query
I would like a suggestion for me to try to solve a problem that a few days
ago.
My GeoServer is connected to a PostGIS database. How can I generate a layer
from a query (sql) generated in a PHP page (thus out of GeoServer)? Ie how
to send query via Post to GeoServer? Thanks
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-s-query-tp5061237.html
Have a look at CQL_FILTER for a light weight solution. If not you are going to have to use the REST API to configure a virtual table (i.e. ask geoserver to publish the result of an SQL statement).
I will point out that GeoServer (as a middleware application) is trying to avoid the use of SQL and make use of an appropriate standard for requests. Not all data sources speak SQL :smiley:
Jody Garnett
ago.
This SF.net email is sponsored by Windows:
Build for Windows Store.
http://p.sf.net/sfu/windows-dev2dev
Geoserver-users mailing list
